2019 Jimny Accessories
29 Apr 2019 14:07 - 29 Apr 2019 14:10 #206905 by mlines
Replied by mlines on topic 2019 Jimny Accessories
mikeyw85 wrote:
Gadget wrote: Would be nice if rear speaker brackets and speakers with the correct wiring harness were available in the UK. Parts 99197-77R10 and 99000-79BJ0-R00.
i second this.
See BigJimny store, they are trickling in, but they are available
www.bigjimny.com/store/rear-speaker-mounting-kit.html
Last edit: 29 Apr 2019 14:10 by mlines.
29 Apr 2019 16:24 #206916 by Gadget
Replied by Gadget on topic 2019 Jimny Accessories
Thanks Martin. That looks like you've got both the front and rear speaker mounting kits there. For the rear speaker install you only need 99197-77R10. The kit with the black speaker surrounds is for the front doors.
If you could split them out, I'll order one of the front kits from you, as I've already installed the rears.
29 Apr 2019 16:51 - 29 Apr 2019 16:59 #206919 by mlines
Replied by mlines on topic Re:2019 Jimny Accessories
No, I have the EU spec REAR mounting kit which consists of two sub kits:
1. The bracket kit
2. The wires and casing kit, which is LABELLED front but is ALSO required for the rear.
The instructions included tell you how to combine the kit.
This is what the EU sells as the rear kit and you have to have both sub kits. I have a Suzuki bulletin somewhere about it.
As I do not have a Gen4 I have not attempted a fit myself yet.
Last edit: 29 Apr 2019 16:59 by mlines.
29 Apr 2019 16:53 #206920 by mlines
My last stock delivery went out on Friday otherwise I could show you the instructions
29 Apr 2019 17:06 #206921 by mlines
Below is a conversation with the Suzuki UK, their responses are in red.
Rear Speaker Fitting Kit 99197-77R10-000 Part Number supplied by customer but invalid when input in to the parts system.
The correct description for this item is Rear Speaker Mounting Bracket - and it’s available under part number 99197-77R00-000. However, as well as these brackets, there is a Rear Speaker Mounting Kit (990E0-78R32-050) that MUST be utilised in order to install rear speakers into New Jimny. Both items can be ordered through our system.
Rear Speakers (Pioneer) 99000-79BJ0-R00 Part Number supplied by customer but invalid when input in to the parts system. I’d suggest that this part number is a Japanese domestic market item only, so is not available to order through the European system. Germany do list an approved Speaker Kit which may or may not (?) contain a set of rear speakers for New Jimny. The info we have received from Germany is a bit vague, so I’m awaiting clarification from them on relevant details.
The following user(s) said Thank You: Bill Portland
29 Apr 2019 17:22 #206923 by Gadget
Replied by Gadget on topic Re:2019 Jimny Accessories
That's really odd. I bought 99197-77R10-000 direct from Japan and it has everything needed to fit the rear speakers - the metal brackets, wiring harness, bolts, screws and foam. Nothing else was needed. The black circular mounting surrounds are definitely not needed to install the rears, but are needed to upgrade the fronts.
Time to create page: 0.234 seconds
