Outage - Friday 26th February
25 Feb 2016 12:03 #162979 by mlines
On Friday 26th February I will attempt a move to the new server I have had under test.
The actual move process is quite quick, I have to synchronise the database between the two servers which will take less that 30 minutes.
However, as it is an actual move of server then the Internet DNS records have to be updated (this should also fix the broken emailing issue). The Internet DNS update is reliant on the change filtering through the internet, this can take up to 24hrs. This is out of my control and is a standard internet issue.
Most DNS records will update within an hour. But a few providers will not update as quick. Therefore you will be left looking at the old site if your DNS has not updated.
If this affects you then you can directly access the new site using test.bigjimny.com
The changes are all "under the hood". It is a complete new build of Linux and the website core. The build is clean and things such as the £ symbol work
The following user(s) said Thank You: Tadpole, Lambert
26 Feb 2016 11:06 #163016 by mlines
Is anyone here yet?
did you use " www.bigjimny.com " as the address?
26 Feb 2016 11:13 #163017 by mlines
  • Daniel30
26 Feb 2016 11:38 #163019 by Daniel30
Replied by Daniel30 on topic Outage - Friday 26th February
I have looks fine ££££££££ :)
26 Feb 2016 12:19 #163020 by grumyoldjoe
Im here (wavey thingy)
At least I think I am :huh:
or am I in the old place
dunno :blush:
Logged in ok though :woohoo:
Wine improves with age.
  • OllieNZ
26 Feb 2016 13:09 #163021 by OllieNZ
Replied by OllieNZ on topic Re:Outage - Friday 26th February
Any effects for tapatalk users?
Time to create page: 0.402 seconds
