Idea?
  • doncarlyon
08 Nov 2011 11:42 #25343 by doncarlyon
Idea? was created by doncarlyon
The boot floor on the Jimny is a well known rot point... same thing goes for the disco's. Yet you can buy a boot floor online for a disco for about 50quid.
Is this something that you could look into doing?
  • viciouspenguin
08 Nov 2011 12:54 #25346 by viciouspenguin
Replied by viciouspenguin on topic Re: Idea?
that probably wont solve the issue, in fact it might worsen it. without the liner you can keep an eye on things, cover it up and it will be harder to check, and trap any moisture underneath it.
  • doncarlyon
08 Nov 2011 13:49 #25348 by doncarlyon
Replied by doncarlyon on topic Re: Idea?
i didnt mention a liner, you have read it wrong.
  • viciouspenguin
08 Nov 2011 14:27 #25349 by viciouspenguin
doncarlyon wrote: i didnt mention a liner, you have read it wrong.
ahh, yes, my bad.
lets use this as an example of what happens when (a) you go on forums via a phone with a 4inch screen when (b) you're supposed to be working.
08 Nov 2011 14:36 - 08 Nov 2011 14:37 #25350 by mlines
Replied by mlines on topic Re: Idea?
The problem with any shop item is whether it would sell. My thinking on this sort of thing is a floor replacement panel would need welding in, if you can weld it in then you don't need a panel as you can bend up a piece of metal and weld it over the hole, hence very little market for the product??
Does this make sense?
This is the reason why as many of my products as possible are bolt on.
Last edit: 08 Nov 2011 14:37 by mlines.
Time to create page: 0.159 seconds
