cutting out
  • r7ynp1988
21 Sep 2011 05:10 #22230 by r7ynp1988
cutting out was created by r7ynp1988
w reg jimny cutting out when warm any ideas cheers ???
  • X-Eng Simon
21 Sep 2011 05:20 #22232 by X-Eng Simon
Replied by X-Eng Simon on topic Re: cutting out
More information would be helpful.
Can you re-start it? Immediately?
Does it happen every time the engine is warming up?
What sort of temperature is it happening at?
Once you've re started it, does it continue to cut out?
Does it still cut out when it gets up to running temperature?
I'm bored of asking questions - but you get the idea of the sort of info required to make a diagnosis.
Si
  • r7ynp1988
21 Sep 2011 08:59 #22248 by r7ynp1988
Replied by r7ynp1988 on topic Re: cutting out
Hi there
Yes it cuts out after approx 3 - 4 miles when the vehicle is at running temp, Wont start again until the engine has cooled down. It happens every time you drive the vehicle. We suspect cam and crank sensors faultey but not100% cheers.
Regards Ryan.
  • X-Eng Simon
21 Sep 2011 19:09 #22303 by X-Eng Simon
On yours it's a cam sensor located at the bulkhead end of the rocker cover. Easy to get at and a replacement is only £25.
They do go faulty, but it should light up the engine warning light.
Other things worth investigating are: (if only to rule them out)
Spark. Make sure the plugs are sparking
Fuel. Sometimes you get fuel vaporising in the feed pipe and / or dirty fuel filter. When the engine is cold, the cold start enrichment might provide enough fuel to run it even with reduced fuel rail pressure. When the ECU thinks it's up to temperature it's switched off and the engine goes lean?
Other sensor faults. Tend to cause hard to diagnose problems. Try pulling apart every connector you can find, spray with contact cleaner, fill with petroleum jelly and re-connect. This fixes a remarkable number of problems.
Behind the glove box you'll find a six pin connector. The diagnostic computer plugs in to this. However, by shorting two of the pins (2 & 4 IIRC) it will flash the engine warning light to indicate what fault codes it sees. Disconnect battery for a minute to reset the codes once you've fixed the problem.
There is lots of info on line about the connector and codes.
This helped me diagnose a faulty cam pos sensor.
Si
  • Sandez
21 Sep 2011 19:53 #22306 by Sandez
Replied by Sandez on topic Re: cutting out
Sounds to me more like the crank sensor. Best way to test is to start the car and get it to running temp until it cuts out. After it cuts out pour water over the cam sensor (to assist it cooling down) and try starting it again. If it starts then you have your problem. If not try the same on the crank sensor. Free and easy way to test.
Also like Si mentioned, the six pin connector is helpful to find faults. Download the workshop manual if you need help finding the plug and the right pins
  • Adamski
21 Sep 2011 20:54 - 21 Sep 2011 20:58 #22309 by Adamski
Replied by Adamski on topic Re: cutting out
I had the same issue.
Replaced the camshaft sensor, didn't fix it.
Replaced the crankshaft sensor, that fixed it :)
I think the cam and crank sensors are about £60 each from the stealership. I couldn't get hold of them from my usual (reasonably priced) source of parts.
Last edit: 21 Sep 2011 20:58 by Adamski.
