SJ Manual Hub Adapters / Bolts
  • doncarlyon
04 May 2011 09:34 #15854 by doncarlyon
SJ Manual Hub Adapters / Bolts was created by doncarlyon
Got them a little while ago, fitted the hubs last night... everything was very straight forward!
Cheers!
05 May 2011 15:47 #15910 by mlines
05 May 2011 16:13 - 05 May 2011 16:14 #15911 by maverick
Martin, do you do those studs with a normal head/nut on the top, instead of a allen-key head ...
They are a serious 'b1tch' to fit as the FWH gets in the way ....
But, on the other hand, no-one is gonna steal them ... unless they've the odd hour to spare!!
Jalapeño, IISY?
Last edit: 05 May 2011 16:14 by maverick. Reason: add more text
  • Keefe
05 May 2011 16:30 #15912 by Keefe
Replied by Keefe on topic Re: SJ Manual Hub Adapters / Bolts
maverick wrote: They are a serious 'b1tch' to fit as the FWH gets in the way ....
If you remove the 'end' of the hub, you can get an allen key straight in, dead easy.
hth
K :)
  • doncarlyon
05 May 2011 16:39 #15914 by doncarlyon
Replied by doncarlyon on topic Re: SJ Manual Hub Adapters / Bolts
Yup, it took about half an hour to do the whole job. Very easy!
05 May 2011 16:46 #15916 by mlines
maverick wrote: Martin, do you do those studs with a normal head/nut on the top, instead of a allen-key head ...
They are still the Hex Head Bolts, as has been said it is straight forward if you remove the end cap of the hub.
There was no specific intention/design about it, they were just the ones I had for the prototype and have been the ones I have bought ever since. If the general concensus it that they should be different then I can change, but if you can't get an Allen Key in then you are unlikely to get a socket drive in either?
Time to create page: 0.157 seconds
