Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
ARB airline - continued
Well the part finally turned up today after nearly 3 weeks of waiting :( I have re-tapped the Diff casing thread as it looks like there is enough metal to form a decent thread. As you can see from the picture, the new adapter also has considerably more thread!
  10072 Hits
Tags:
Stabiliser/Drop Link - MOT Time
​So the MOT time is approaching for "LittleJimny" and we knew that one of the stabiliser links (or drop links) is bent and leaking grease. It is a straight forward process to change these although inevitably occasionally things get stuck. Here is the old link in position, all you have to do is undo the two nuts securing it. ​ As they are swiveling ...
  12118 Hits
What the postman brought....
I used to have a rear disc conversion fitted that I really did not get on with. It never seemed to work properly and needed constant attention in order to get any sort of braking capability. This has been delaying my rebuild as I could not be inspired to re-fit it and go through the trials again. However, I have bitten the bullet and bought a new k...
  10691 Hits
Tags:
Spotted on M3 slipping to A34 North
Spotted - I think its Ali?
  9712 Hits
Tags:
Latest visitor to the store
  12493 Hits
Tags:
