Fitting a lift kit to a Gen4 Jimny
Resized_IMG_20200504_184546
One of the most common upgrades people want to do to their Jimny is to lift it. This can be for a number of reasons varying from "the look" through to fitting large tyres or replacing a tired suspension. We like the look of a slightly perkier Jimny, not a soaring lift but just enough to make it look a bit more purposeful.
I have videoed the experience and the videos are below......
  8951 Hits
Tags:
Modifications and Upgrades to our Gen4 Jimny
Resized_IMG_20200504_185045
Over the past few months I have been carrying out some little modifications/upgrades to our Gen4 Jimny and created some video guides.......
  11360 Hits
Tags:
Baofeng DM-9HX DMR
Notes on the programming and use of a DM-9HX DMR Radio.
I have put these together as a simple reminder to myself on "how I did it" and also as a help to others. The challenge with Digital Radio is that it is binary, it either works or it doesn't, there is no inbetween version of "I can just hear you " or "it nearly works". Playing around with DMR, you will hear a lot of silence!
DMR for Amateurs has evolved from commercial digital systems such as Tetra etc. This means the firmware code in radios tends to be similar to that you would expect to find in a police/security/PMR device, ie. channels are all pre-programmed and the end user has little or no control over channel settings in day to day use. Therefore a lot of the work setting it up is done from the computer and not the radio. Apparently a high end radio such as the Anytone 878 will allow much more Amateur "on the fly" programming, but the Baofeng DM-9HX is only around £65 so the intelligence is in the computer setting up and not the radio.
  15902 Hits
RockLobster Build - Part 3 - Re-assembly
Processed-IMG_20200112_19104013
This three part article covers my building of a RockLobster 6.5:1 transfer box. The article parts are:
  • Part 1 - Dis-assembly (see HERE)
  • Part 2 - Building the gears (HERE)
  • Part 3 - Re-assembly (this part)
  14547 Hits
Tags:
Keithy's Trayback
20200110_183845
Has power been an issue for your Jimny?
It's not an issue here! Check out Keithy's Trayback build
See Read more...
  9868 Hits
Tags:
