07/07/08 - Cargo net mod from Chris
A modification sent in by Chris - Many thanks.
As my Jimny is also my daily drive, one of the things that I don't always enjoy is the lack of useful storage space. This led me to conclude that the concave space in the rear door needed to be used, otherwise it is wasted space, so I made this little modification...
The net cost me £6.31 from ebay (including postage) and I've used about 1/4 of what I bought, the bungee cord came with the net. The little tabs are made from cheap nylon webbing, to make 8 of them used about 1.5ft of strap. By taking the door card off I was able to drill through and use washers on the back side to give the whole assembly a lot more strength, which I hope will prevent the nuts from pulling through the plastic door card. It's ideal for holding waterproofs, hi-vis vests, gloves, shopping bags etc, and they will fold flat into the door if the boot is full of other stuff
Chris
  16447 Hits
04/07/08 - Smiffy and Macs ASBOJimny
Here are some pictures of Smiffy and Macs  ASBOJimny build. As you can see they started with a standard Jimny only a couple of weeks back....
So why "ASBOJimny"? Well its registration has the letters ASB in it and for those of you who are not in the UK an ASBO (Anti-Social Behaviour Order) is a warning issued to people who are deemed to be acting "Anti Socially" - so I guess this is going to be a monster!.....
  9074 Hits
01/07/08 - Chris' Jimny
Chris has sent in these pictures of his Jimny on its first green lane adventures. At present it is standard, but watch this space as he wants to develop it further and it will be nice to see it change.
For more pictures - see below
(And for anyone who hasn't sent in pictures of theirs yet - why not - drop me a line through the contacts section of this website!)
  9489 Hits
28/06/08 - The Trailing Arms (not the name of a pub!)
So the loud clonk (see HERE ) has been located.
I took off the wheels and removed the rear trailing arms. At first the arms looked ok, whilst the rubbers show signs of wear they are certainly not worn out. However a glance back at the mounting point showed the real source of the problem....
  8561 Hits
26/6/08 - A loud clonk!
My Jimny has gained a significant clonk when letting up the clutch, there is also a lot of drive chain "shunt" and rubber "squeaking" whenever the back axle is exercised in any way.
I have crawled underneath and pushed and pulled things.
  10043 Hits
