BigJimnyMeet 2024
Just purchased my first Jimny
- Thank you received: 28
26 Jan 2019 10:11 #201733
by adrianr
About Wee Jimmy : www.bigjimny.com/index.php/forum/8-my-ji...-first-jimny?start=0
Replied by adrianr on topic Just purchased my first Jimny
Since I have fixed hubs and have disabled the vac system I blocked the vac pipe coming off the throttle body to the vac manifold for the 4wd system.
Idle is now nice and smooth so I guess there must have been a leak somewhere.
26 Jan 2019 14:41 - 26 Jan 2019 15:12 #201746
by adrianr
Crank sensor, radius arm bolt, oil filter and tie rod end arrived - Martin - that is amazing service, thank you.
Extended brake lines from Llama 4 x 4.
Crank sensor fitted.
Tie rod end fitted.
Went to do the brake lines to find the bleed nipples unwilling to turn.
Have to get some more bleed nipples and then I can apply some heat and more force to these stuck ones to persuade them to leave.
Traced the wiring to the interior LED near the back seats a previous owner had fitted. Once I refitted the LED it appears to be working for now.
It started raining too so gave the wee car a wash and called it a day.
Tie rod end fitted.
Last edit: 26 Jan 2019 15:12 by adrianr.
- Thank you received: 82
26 Jan 2019 16:58 #201756
by Dirtbird
Heavy Duty Transfer Box Brackets, 2-inch Black Raptor lift kit, caster adjusters, Rust removed and stich welded new sections. Galvanised Chassis. Body,Engine,transmission swap. Anti Rollbar Roll / Sway Bar / DAVES ARB disconnect kit.Osram Night Breaker Head light mod and white 501 led side lights.
Replied by Dirtbird on topic Just purchased my first Jimny
Nothing like progress. Think I'll out on me kettle and have a cup of tea.
The following user(s) said Thank You: adrianr
27 Jan 2019 10:42 - 27 Jan 2019 10:42 #201821
by adrianr
Popped off the bumper and driver's side wheel arch liner to deal with the white plastic clips that resonate when I accelerate.
It looks like the tin worm has been busy. I suspect the other side may well be similar. After a few light taps with a hammer...
Gave it some rust treatment to slow it down - will get new metal welded in place in the spring.
Last edit: 27 Jan 2019 10:42 by adrianr.
- Thank you received: 1761
27 Jan 2019 11:49 #201832
Replied by Lambert on topic Just purchased my first Jimny
Martin can supply complete replacement panels for that area.
27 Jan 2019 11:51 #201834
by adrianr
Awesome - thank you.
29 Jan 2019 12:24 #202017
by adrianr
Wee Jimmy still has, from what I can see, the original battery. Been pretty tired since I bought him and the very cold mornings have finished it off. Ordered a new Yuasa with a few more CCAs.
29 Jan 2019 12:53 - 29 Jan 2019 12:54 #202020
I have one of those on my tractor. Seems to be a good quality battery even with the occasional use the tractor gets.
Last edit: 29 Jan 2019 12:54 by Lambert.
29 Jan 2019 19:48 - 29 Jan 2019 19:48 #202039
by adrianr
Almost all done now...
The bleed nipples were stuck tight - took a lot of heat and some persuasion but they finally gave in. Thanks to my mate Ian who is a mechanic of 28 years. He was originally helping then stepped in, whipped the calipers off and set to in a vice with his torch and grips. Took some work but as with everything it eventually gives in with enough focus and applied effort.
So no we have new bleed nipples and the longer stainless brake lines from Llama 4x4.
Brakes all bled.
Turned attention to the knock from the back radius arm. When we pulled the old bolt that wouldn't torque up properly the holes looked fine. So we popped in the nice shiny new high tensile bolt Martin sent and that torqued up fine. So fingers crossed. Was certainly quiet on the short run home.
The new battery is on its way. Should be here Thursday or Friday. Meantime I have an older battery from my mates Mk4 tdi Golf in the boot with my jump leads so if I cant park on a hill and bump start, I won't have to beg a jump start from a passing motorist. At least that’s the plan!
Brakes all bled.
Last edit: 29 Jan 2019 19:48 by adrianr.
29 Jan 2019 20:04 #202043
Sounds like a productive day!
29 Jan 2019 21:24 #202051
by adrianr
Thank you Lambert. Yes, well pleased with today's progress. It all got done in about 90 minutes this evening.
Just pulled the old battery out and will leave it on charge overnight. Might be able to coax a start or two tomorrow, or perhaps not. Best I got today was central locking, interior LEDs and a single click from the starter.
- Max Headroom
- Banned
- Thank you received: 217
29 Jan 2019 21:29 #202052
by Max Headroom
Replied by Max Headroom on topic Just purchased my first Jimny
Good work Adrian.
...And I like the idea of carrying a spare battery just in case. However make sure it can't fall over and leak acid everywhere!
Time to create page: 0.169 seconds
