Re:The Jimny of the Yakuza
- Thank you received: 333
Have been driving with the 87% low/17% high reduction now for a couple of weeks and this kit goes well with my 235's. Much more smooth and flexible thru the grears at normal driving. It is a bit high rpm for highway use but not too bad.
First trip was going south for a 8 hour drive with a 600kg trailer. Just as well to get used to the abuse right away
There is a lot of gear noise when the gears are new but it got much better thru the first 1000km. Still whines a lot though so if you do not need the lower gearing in the high range i would considering not to fit it and settle with the 70% reduction in the low range. With my experience now i am not sure i would fit the high range again if i knew the noise would be like this.
I kept the original gears of course so i might remove the high range reduction some time in the future if i don't get used to the noise.
It think that at that price the gears should have been ground and polished for less noise. I still would pay more if i knew they had less noise.
Hoping it will get a bit better after an oil change.
Annual meet coming up so i have te get the car ready:
- check the brakes
- check for play in the front
- change engine oil
- change transfer gear oil
- mount my CB radio, under car camera, led bar and other stuff if there is time..
- check the brakes
- change engine oil
Done:
Brakes checked. slight oil residue in the rear drums so I will have to change the seals. just cleaned for now.
Checked front end for play, found nothing. Will have to get the wheels balanced.
Transfer oil change done. Oil did not look too bad but some grey matter from the new gear wheels.
CB mounted and antenna adjusted and checked.
The meet was postponed due to forest fire hazard so I got until September now..
After reading someones post about flushing the catalytic converter i thought i would give it a go in the weekend. flushed it out and blow dried with my dogs big blower fan. kind of helped a bit so yesterday i went to the Biltema (Halfords lookalike) and bought a universal cat converter for NOK699 approx GBP70. Also bought a M18x1.5 weld nut for the lambda, drilled a hole in the same position as in the old cat, and welded it.
Then cut out the old cat from the pipe and welded in the new cat.
WOW the difference!
Now i got power above 4000rpm!
Haven't tried going uphill yet to check if the ignition pinging is reduced, but wouldn't be suprised if it helps.
Only regret now is that I did not change the complete pipe for a 2". the bend from the manifold and down to the cat is tiny..
It looks ok on the outside but it is a double pipe with insulation so the inner diameter is like 40mm.
Next now is to tidy up my electrical connections and get the wheels balanced and I'm off on Friday morning!
- OlaGB
- Visitor
Nice fix!
But I'll post some later..
New regulations for lights now so I'll probably buy 3 or 4 7" lamps to put there..
Silver car has 215's and m16 otherwise original. Not mine, a colleague.
Have been considering black bedliner on bumpers and arches.
Not sure anymore but front bumper is well scratched..
- OlaGB
- Visitor
A Bit Windy this new years day so our Boat House got it.. This picture is when we got the boat out unharmed luckily.
Have no idea how I could do this without the Jimny. Probably would have to buy a tractor or something.. Pretty steep grass hill to get down to the sea here from the road. Used the Jimny to pull out the other boat as well helping the insurance people. Hoping insurance will cover most of the damage.
Finally got time today to fit Diesel jimny vented brake discs and Vitara 5 door calipers.
Old discs looked awful with a sticky black something on them and rusted spots as well.
Also had some brake wobble emerging again.
No issues with the job, just plug and play.
Bought calipers with brackets and shoes years ago for my SJ but the SJ do not need brakes yet.
No problems venting the air out of the calipers and lines. Just lay the brake disc with caliper on on the side on top of the axle with the caliper vent upright.
Also did my rear brakes as they had been looking bad inside due to brake fluid leakage. Changed both sides cylinders and shoes. But on one side there was also oil so changed the axle oil seal as well. Nice to have a well stocked shelve with SJ parts. Oil Seal was the same.
Brakes now feels good of course, but the improvement on my car was mostly due to the worn parts i swapped off it.
- Thank you received: 1763
Boat shed new year celebrations. Wind came suddenly from the wrong side. Can't remember it coming down the hillside like this ever.Lambert wrote: Ignoring the fact that your boat shed seems to have had too much vodka, I'm not at all envious of you, no sir, not one bit jealous! What a beautiful place to live!
It sure is beautiful, funny how I never thought of it like that when I lived there growing up.. It was just an old ragged sheep farm.
No sheep since 1990 here, but the neighbors sheep still holds the forest off the fields.
I do not live there, but hoping to have a cabin or something here one day. My uncle owns the place now.
