MY 2003 JIMNY....FROM TASMANIA, AUSTRALIA
- Thank you received: 210
Attachment tap_5.jpg not found
Attachment 281526_10150251525253218_711258217_7507017_3745928_n.jpg not found
He used one of these to cut a thread in to the transfer box.
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
- chechan rebel
- Visitor
renard38 wrote:
how did you fix it??( i hope you understand)
Im not sure what you mean........................but, it had a standard breather cap, i took that out. Then drilled
it out, then tapped a 10mm thread into it an put a fitting into it an ran a hose out of it into my snorkel so transfer case breathes out of snorkle.......................same as both diffs an gearbox.
As dirtydogz shows above...............If you look at 1st an 4th pic youl see my tapp laying on ground.
I also had to tapp both diffs for there fittings, gearbox didnt need to be.
- renard38
- Visitor
- chechan rebel
- Visitor
Attachment 293690_10150280745708218_711258217_7781697_810962836_n.jpg not found
Attachment 295966_10150280745568218_711258217_7781695_919318524_n.jpg not found
Attachment 304412_10150280745513218_711258217_7781694_1041636880_n.jpg not found
Attachment 308698_10150280745443218_711258217_7781693_71622267_n.jpg not found
Attachment 315022_10150280747573218_711258217_7781703_967980781_n.jpg not found
Attachment 319135_10150280745358218_711258217_7781692_374057630_n.jpg not found
Attachment 321050_10150280745273218_711258217_7781691_1488270138_n.jpg not found
Got windows tinted...............
- chechan rebel
- Visitor
- renard38
- Visitor
- Monkey
- Visitor
chechan rebel wrote: Few new pics coming soon...............new bonnet scoop, 50mm front spacers, 20mm rear..........+ 50mm body lift.
What size tyre's do you plan on running with that much lift? 33's?
- jaykay
- Visitor
What part of Tas are you from?
- chechan rebel
- Visitor
jaykay wrote: Wow loving the white Jimny, and the front window sticker !!
Hobart at the moment, but just bought 10 acres at mangana east coast gold country so will be up there 3-4 months tops.....................
Monkey......just 30"s bro.
- chechan rebel
- Visitor
- jaykay
- Visitor
chechan rebel wrote: Been thinking long an hard last week or so........................... I think im gunna turbocharge this bit##.
Do it!!!!
- chechan rebel
- Visitor
Attachment 376856_10150355238473218_711258217_8207197_152715064_n.jpg not found
Attachment 375335_10150355239203218_711258217_8207206_842458012_n.jpg not found
Attachment 321226_10150355239498218_711258217_8207210_2089051494_n.jpg not found
Attachment 320084_10150355239953218_711258217_8207215_874173139_n.jpg not found
Attachment 319150_10150355240833218_711258217_8207224_217373864_n.jpg not found
Attachment 318665_10150355238543218_711258217_8207199_968593943_n.jpg not found
Attachment 300978_10150355238393218_711258217_8207196_660391644_n.jpg not found
Attachment 300181_10150355238668218_711258217_8207201_1691588336_n.jpg not found
Attachment 298530_10150355239288218_711258217_8207207_1402493122_n.jpg not found
Heres some latest work, bonnet scoop, re grease steering knuckles, front 50mm spacers, rear 20mm.
