Don's Jimny
- bertbuckie
- Visitor
The bad snow this year I drove a hell of a distance down untreated single track roads in as much as 2-3 foot drifts...... it got stuck once or twice but soon regained traction to escape - It was going places all the q5's and q7's and x5's etc couldnt..... with road tyres and no lift so it's more than capable in my eyes and if she carries on like this I will be looking at another zuki when I need more space - Hopefully there all so good
- doncarlyon
- Visitor
Does anyone know how much the MPG is affected by having the front hubs locked? i.e. the vacuum system not working?
- Thank you received: 34
Former owner of Little "Ooky", who has now started a new life in Shetland
- bertbuckie
- Visitor
Mines about 240 miles on a full tank in 2wd without the hubs locked..... on mixture of length trips ( and I barely ever go over 50-55mph )ooky_123 wrote: Mine does about 200 miles on a full tank ... mind you, that is also with 2" suspension, 2" body lift & 215x80 rubber ...
- doncarlyon
- Visitor
Similar mods to mine, are your fronts locked or not?
Cannot get over 50 mph unless in 3rd gear and ringing its neck !
Off road, I can do about £150 miles before she is almost dry though .. that running 4x4 all the time
- doncarlyon
- Visitor
I might invest in some AVM manual hubs, can always sell them on if the MPG / Power isnt really affected by the fronts being locked.
Painted my spare wheel black today. Not a brilliant job but better than it was!
- bertbuckie
- Visitor
Today I changed one side of the signum front brake discs and hoovered out the jimny and signum while the wife flash dashed them
- downhilldude
- Visitor
Whats this about locking front hubs? Could anyone explain this?
I've heard about this but I didn't know there was a way to lock/unlock the front hubs?
He's getting that mpg with just in 2WD.
Cheers.
- doncarlyon
- Visitor
Some people fit manual hubs, others permanently lock the front hubs to the driveshafts. In this case, even in 2wd, the front wheels are turning the driveshafts / diff / propshaft. which causes more "drag" and will use more fuel and sap power... how much doesnt seem to be known.
- downhilldude
- Visitor
doncarlyon wrote: The front hubs are vacuum operated, when they fail you cant get 4wd as the front hubs dont "select". So although the transfer box is sending power to the front diff, the front wheels arent engaged so arent working.
Ah ok, and is the vacuum system breaking a common problem?
So if your vacuum system is working when in 2WD the front hubs should be fully disconnected?
My friend seems to have pulled out, what I think to be is a vacuume hose, it's routed under the rear arm. I pushed it back in and everything seems to be working 100% in 4WD and 2WD.
Cheers.
- adamjimny
- Visitor
