Re:Re:Wandering on the Road
- Thank you received: 16
Thanks for that, found one on t Fleecebay 275654720824 for £34.95 so TBH wasn't sure it was worth the effort as I'd have to buy the steel, went with a MK1 damper £25 hope it fits, as his kit with a damper worked out at £45 for the damper.If you can fabrication yourself my damper kit cost about 30 quid and a couple of hours
Use a Mk1 disco damper around 20 quid on ebay
Also ordered the castor kit, so figure on getting it all fitted & then take it to get the tracking checked so next question, do you use factory setting for the toe when lifted 2"
- Thank you received: 372
The kit (brackets) are easy to fit, I did mine in about 30 minutes in the dark late one afternoon, just centre the steering and then pull the damper out about half way before adjusting the nuts on the threaded bar.
If my damper gives up the will to go on then it will be replaced with a £25 job like yours.
Together with your tow bar that’s going to be another job done in the dark, ah the joys of [winter] motor mechanics.
Robin
- Thank you received: 653
has for tracking yes you use factory which I think is + - 3 degrees
If you can afford it i would fit 4 new track rod ends 2 left hand thread 2 right hand thread
Also buy new nuts I got mine from jimnybits
- Roger Fairclough
- Thank you received: 194
Roger
Only thing is, you may need to wait a while, they aren't able to keep up with local demand.
- lookonimages
- Thank you received: 64
Had the dessol 50mm with Gabriel shocks. Very tempting to get the new shockssaxj wrote: I just fitted the EV1 Monotube shocks from Des Sol (des-sol.co.za/the-des-sol-ev-shock-absorber-series/). No more wandering, no more wobble, no more adverse reaction from irregularities or pot holes in the road. My Jimny now handles better on the road than my SX4.
I have been through 3 sets of Gabriels in 4 years. Their quality was not what it should be. Now they don't exist any more.
The EV1's are expensive, but well worth it. I am really pleased with them.
Is there any adjustment on the steering box, I was looking yesterday there looks to be a little play from turning the wheel before the arm moves coming out of the box, but it's very difficult on your own to be at both ends at once. Seem to remember back in the 70's being able to add a little more preload to take up some of the slack.
But only turn/tighten the center part in 1mm increments
Taking all the slack out is a really bad thing to do
Sent from my ThinkPhone by motorola using Tapatalk
Might try the castor bushes tomorrow, not 100% sure what she has planned for me, hopefully not a lot.
