BigJimnyMeet 2024
× A place for more technical discussions. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Converting Vacuum hubs to fixed hubs
  • Butta
  • Visitor
  • Visitor
20 Nov 2014 23:20 - 20 Nov 2014 23:21 #130207 by Butta
Replied by Butta on topic Converting Vacuum hubs to fixed hubs
Great work and I will be doing similar to mine but have one question how much steering lock is lost (or rather unusable) on high grip serfaces with locked front hubs so as not to destroy the cv joints?
Last edit: 20 Nov 2014 23:21 by Butta.
The topic has been locked.
21 Nov 2014 09:13 #130218 by kirkynut
Butta wrote: Great work and I will be doing similar to mine but have one question how much steering lock is lost (or rather unusable) on high grip serfaces with locked front hubs so as not to destroy the cv joints?
None at all. You have a diff in the front axle.
The issue of transmission wind up which stops good steering when in 4wd on a hard and grippy surface comes from there not being a centre diff.
As you are not in 4wd the front prop is not engaged in the transfer box so if free. Thus no wind up is created.
21 Nov 2014 09:35 #130220 by mlines
A good write up.
Its also similar to a "field bodge" you can do when they fail off-road. Undo the hub with a Torx, pull the centre out into the locked position, drop a small nut from your parts box through the centre of the hub and jam it in behind the slider (this prevents it unlocking accidently).
Its a real bodge but I have used it to stop the hub failure ruining an off-roading day.
  • Butta
  • Visitor
  • Visitor
21 Nov 2014 09:43 #130223 by Butta
Twice it has happened to me that my hubs have not disengaged after a period in 4wd and on both occasions the car behaved as if the front brakes were stuck on if full lock was attempted I thought this was due to the cv's as once I have got them disengaged by putting it in and out of 4wd a few times I could use full lock again
21 Nov 2014 22:43 #130305 by kirkynut
Butta wrote: Twice it has happened to me that my hubs have not disengaged after a period in 4wd and on both occasions the car behaved as if the front brakes were stuck on if full lock was attempted I thought this was due to the cv's as once I have got them disengaged by putting it in and out of 4wd a few times I could use full lock again
Advice given by PM and thread tidied back to original topic.
  • GuardianAngel
  • Visitor
  • Visitor
28 Nov 2014 12:29 #130802 by GuardianAngel
Replied by GuardianAngel on topic Converting Vacuum hubs to fixed hubs
Good thread :)
I have some spare vac hubs and my locking hubs need a service as they no longer work. So I am going to attempt this today/tomorrow and test it out during the week.
Hope your recovery goes well :)
  • GuardianAngel
  • Visitor
  • Visitor
28 Nov 2014 13:58 #130808 by GuardianAngel
Just taken one apart but could not get the casing apart. So a quick trip to the hardware store for some pipe that just fits snugly from the back seems to do the job (14mm OD is needed).
As the pipe is short it seems quite strong so should not collapse.
01 Dec 2014 09:11 #131165 by kirkynut
That might make it easier for people to be able to do it mate. I have a well equipped workshop at the end of my garage but I appreciate not everyone has the luxury.
  • Butta
  • Visitor
  • Visitor
02 Dec 2014 13:02 #131297 by Butta
Ok did this mod today using the original kirkynut method and some stick on rubber 'appliance feet' which are 22mm wide and 10mm tall working on the kitchen floor with a hammer and small chisel took about half an hour in all have got 2 spare of the spacers I used if anyone wanted them
  • Butta
  • Visitor
  • Visitor
07 Dec 2014 09:31 #131731 by Butta
Ok ive done 100 miles since this mod and it drive's exactly the same no difference to noise or fuel economy my issue with full lock was due to transmission wind up (my transfer box sticks in 4wd if I have wind up even though the lever moves easily back to the 2wd position a small amount of reversing sorts it) and the fact i have a lane 10m from my front door!
  • GuardianAngel
  • Visitor
  • Visitor
07 Dec 2014 17:58 #131763 by GuardianAngel
Replied by GuardianAngel on topic Re:Re: Converting Vacuum hubs to fixed hubs
kirkynut wrote: That might make it easier for people to be able to do it mate. I have a well equipped workshop at the end of my garage but I appreciate not everyone has the luxury.
I went on a full landing trip last night and all is good. Also been out on some fast roads and even got up to 60 mph :lol: but evidence of wobble or vibration from the wheels.
07 Dec 2014 19:24 #131773 by kirkynut
Is that meant to mean no evidence of death wobble?
Time to create page: 0.118 seconds
Powered by Kunena Forum
