BigJimnyMeet 2024
× A place for more technical discussions. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
URGENT - How many balls do you have?
  • Frankenjimny
  • Visitor
  • Visitor
11 Nov 2014 16:30 #129238 by Frankenjimny
Replied by Frankenjimny on topic URGENT - How many balls do you have?
Update - unfortunately I can't find any supplier in the UK who can supply me with the newer 8-ball CV joint replacement kit - except for the genuine Suzuki ones which cost about £375+VAT. The Jakopart and Meyle ones do not seem to be available here. And none of the online breakers (e.g. Cam-Suzuki) have a newer axle that they are prepared to strip out (they prefer to sell the whole axle complete). So the only choices it seems are:
1. Buy a genuine Suzuki replacement
2. Try and import an aftermarket replacement
3. Buy a used old style 6-ball replacement half-axle and hope it fits and does not cause problems.
Looks like I'll be shelling out for a Suzuki part :(
  • minitehnicus
  • Visitor
  • Visitor
11 Nov 2014 18:25 #129250 by minitehnicus
Replied by minitehnicus on topic URGENT - How many balls do you have?
uk is an expensive country.
the genuine 44101-84A00 cost here 445 euros or 355 pounds.
11 Nov 2014 19:14 #129254 by mlines
Frankenjimny wrote: The Jakopart and Meyle ones do not seem to be available here.
Well they are listed with my distributor but only in the equivalents table and the table points them to the 6-ball joint.
Their master document does not describe the cage/balls. Instead it gives this table:
CV1569N
Seal diam.: 28 mm, Int. teeth. wheel side: 20, Ext. Teeth, wheel side: 26, Ø: 72 mm, Overall Height: 166 mm
20 internal splines, manual transmission, model code FJ. Engine code g13b
Then there is another listing for
JCV501n
Seal diam.: 28 mm, Ext. Teeth, wheel side: 26, Overall Height: 166 mm, Ø: 72 mm, Int. teeth. wheel side: 19
Manual, auto, model code FJ, engine code m13a g13b,
The following user(s) said Thank You: Frankenjimny
11 Nov 2014 20:31 #129261 by X8GGY
Frankenjimny wrote: Update - unfortunately I can't find any supplier in the UK who can supply me with the newer 8-ball CV joint replacement kit - except for the genuine Suzuki ones which cost about £375+VAT. The Jakopart and Meyle ones do not seem to be available here. And none of the online breakers (e.g. Cam-Suzuki) have a newer axle that they are prepared to strip out (they prefer to sell the whole axle complete). So the only choices it seems are:
If it helps, I've got a couple, as I've changed my front shafts to 26 spline -
www.bigjimny.com/index.php/forum?view=topic&catid=11&id=55765
Dave
  • vitara_mad
  • Visitor
  • Visitor
11 Nov 2014 20:41 #129262 by vitara_mad
Replied by vitara_mad on topic URGENT - How many balls do you have?
not much point paying £40 + postage to refurb a cv when you buy a new cv for £50
  • Frankenjimny
  • Visitor
  • Visitor
11 Nov 2014 20:41 - 11 Nov 2014 20:44 #129263 by Frankenjimny
Yeah thanks, one of my local motor factors had the part no. listed, but it had a note saying not applicable to my vehicle registration. They got one in for me just in case, but yep, it turned out to be the old 6-ball type. I've contacted a couple of UK CV specialists to see if they can help - hopefully get replies back tomorrow.
Last edit: 11 Nov 2014 20:44 by Frankenjimny. Reason: Quoting went wrong
  • Frankenjimny
  • Visitor
  • Visitor
11 Nov 2014 20:48 #129265 by Frankenjimny
Dave
Thanks Dave, I'll see how things go, but could be interested. At least if you've swapped yours then I know that they are definitely interchangeable. I wonder if there would be any implications of having the nearside 8-ball and the off-side 6-ball? I don't do any real off-roading, I just live down a rough track!
11 Nov 2014 21:27 #129270 by mlines
vitara_mad wrote: not much point paying £40 + postage to refurb a cv when you buy a new cv for £50
Because you cannot always get the new CVs depending on UK wide stocks.
Sent from my Nexus 5 using Tapatalk
12 Nov 2014 09:30 #129296 by mlines
For anyone who does want the genuine Suzuki part its £385 including of VAT with postage extra from the Bigjimny Store
  • Frankenjimny
  • Visitor
  • Visitor
13 Nov 2014 09:54 #129382 by Frankenjimny
CV1569N
JCV501n
This suggests that apart from the CV joint the shafts are identical except that there is a difference in the number of Int. teeth wheel side 19 vs 20 (I believe this refers to the diff end). So in fact the two shafts would not appear to be interchangeable.
Glad to see you can offer the new shaft at a more reasonable price Martin, however I have already managed to get one at a similar price from a local dealer, otherwise I would have got it from you. Its a shame the Jakopart or Meyle versions don't seem to be available in the UK and none of the CV/driveshaft specialists I contacted were able to help. But thanks to everyone here for your help - I should be back on the road for the weekend anyway!
Time to create page: 0.126 seconds
Powered by Kunena Forum
