BigJimnyMeet 2024
Removing steering box?
- Smoggy
- Visitor
08 Jul 2012 13:47 - 08 Jul 2012 13:48 #43704
by Smoggy
Removing steering box? was created by Smoggy
I need to get the steering box into my vice to remove the pitman arm, but im not sure how to disconnect the high pressure hose assembly from the car. The hose connections appear to be some kind of special fitting linking the flexi pipe to the solid pipe sections.
Is there an easy method for doing this please?
Last edit: 08 Jul 2012 13:48 by Smoggy.
- markyp2000
- Visitor
08 Jul 2012 14:00 #43706
by markyp2000
Replied by markyp2000 on topic Re: Removing steering box?
remove the rad just to get more room then just undo the bolt that goes through the thick pipe on the right as you look down on it and the other on just take the hose clip off and pull the pipe off
- Smoggy
- Visitor
08 Jul 2012 17:48 #43725
by Smoggy
Replied by Smoggy on topic Re: Removing steering box?
Yeah sorted that just like you said Mark.
Next big task was to get the pitman arm bolt off, ready for the new drop arm to go with my lift. Got the really tight bolt off with easing oil, heat and the help of my windy gun - eventuallly.
Then I found the pitman arm was welded onto the box splines, despite heat and easing oil and the help of my slide hammer attached to a puller it still wouldnt budge
So ive left it overnight steeped in plusgas.
- markyp2000
- Visitor
08 Jul 2012 18:15 #43726
by markyp2000
try some pipe frezze from a plumers center and try and freeze the splines so it shrinks just an idear let us no how you get on
- aniesigh
- Visitor
08 Jul 2012 18:34 #43730
by aniesigh
Replied by aniesigh on topic Re: Removing steering box?
Are you re-using the pitman? try welding all around it on round part of the pitman that has the splines on the inside, then when its real hot try smacking it off
- markyp2000
- Visitor
08 Jul 2012 18:49 #43733
by markyp2000
NO he says he has a new one to go on with hes lift
- Smoggy
- Visitor
08 Jul 2012 18:58 #43737
by Smoggy
Welding bits on wont really help. Ive been smacjking the pitman arm with a spanner and then heating it up and attaching a slide hammer with puller attachment around the arm to belt it off. Ive left it soaking in plusgas and gonna try again tomorrow. If that doesnt work gonna try freezing the box shaft then heat the arm and smack it off. Failing that I will have to try sawing a diagonel to split the arm but its risky cos if I go too far I bugger the splines.
- markyp2000
- Visitor
08 Jul 2012 19:06 #43740
by markyp2000
NO hot and cold dont go well you could damage it more id be more inclind to cut it off just take care also dont forget about the oil seal around the end of the shaft when heating it up when your heating it up are you getting it glowing red hot
- Smoggy
- Visitor
08 Jul 2012 19:16 #43744
by Smoggy
No not glowing, too worried about damaging the steering box.
However ive just discovered another unrelated problem. Whilst submitting these threads my son has been playing in the jim, spinning the steering wheel round and round with no steeringshaft attached
Not sure if the wheel will need centralising or how to do it
- aniesigh
- Visitor
08 Jul 2012 19:27 #43746
by aniesigh
Drive along with no hands on the wheel, then re-fit steering wheel without turning the wheels at all, wheels will be going dead straight due to castor angle.
i didnt mean weld anything too the pitman arm, literally run a bead of weld around it to heat it up, the heat (at first) will be very localised to the arm itself rather than heating the whole lot up with a blow lamp (splines will also be expanding so not gaining you alot) then give it a god smack as soon as you stop welding
- markyp2000
- Visitor
08 Jul 2012 19:27 #43747
by markyp2000
did the steering lock not go on well if he has spun it that much it may have damaged the airbag ring behind the steering wheel its wound like a clock spring
- Smoggy
- Visitor
08 Jul 2012 21:06 #43759
by Smoggy
Keys were in the ignition, so no
Time to create page: 0.099 seconds
