Forum
Suzuki Jimny
Jimny Chat
Lift kit for Gen.4
BigJimnyMeet 2024
Lift kit for Gen.4
Thank you received: 8
19 Mar 2024 21:26 #255179
by Hughes
Sorry for the Hijack....
Most people only RTI score on the front wheel, i.e. driving up forwards. For the record a JK Wrangler Rubicon scores 640 for the LWB and 830 for the SWB model. I believe the new JL does slightly better.
Yeah but who wants to drive a jeep!!?
Thank you received: 66
20 Mar 2024 07:54 - 20 Mar 2024 07:55 #255182
by saxj
Not wanting to dispute how your vehicle performed. But I'd need some convincing that the front anti-roll bar is that limiting
Dug up some notes from testing I did a few years back, when I was considering making a swaybar quick - disconnect for my gen3. Lifted a rear wheel on one side with a forklift until the front wheel on the same side came off the ground. Dropped back down until the front wheel just touched the ground, and measured the distance between the bottom of the rear wheel and the ground. (Vice versa for front axle). Did this with and without swaybar fitted.
This is what I found:
Rear axle went from 410 to 500mm - 75mm (3.5") increase in articulation.
Front axles went from 375 to 480mm - 105mm (4") increase in articulation with swaybar removed.
Did have a King Springs 40mm lift kit installed during this test.
I drove it afterwards with the sway bar removed, was pleasantly suprised at how much better it was to drive so abandoned the swaybar quick-disconnect idea, put the swaybar in the back of the shed and it's never been on the vehicle since.
I drive "defensively" and try not to be in a rush to get anywhere so I've never even felt remotely unsafe driving it like this. Of course, I can't in good faith recommend others doing the same as everyone's situation is different.
I won't be removing the ARB on mine, but might fit an aftermarket disconnectable one.
I think the Gen 4 must be quite similar as standard to the Gen 3. Completely stock I got these figures:
Jimny - front 14” - RTI = 462
Jimny rear 17.5” - RTI = 578
Your modded figures are:
Front RTI = 624
Rear RTI = 650
So pretty good gains over stock.
My gen 3 and my SJ's RTI Scores...
My Gen 4 with ant-roll bar removed, no measurements yet, but goes up that ramp about the same as the Gen 3 did...
Last edit: 20 Mar 2024 07:55 by
saxj.
The following user(s) said Thank You:
Busta
Thank you received: 740
20 Mar 2024 11:27 #255188
by Busta
Since we're already off topic, I can confirm that disconnecting the ARB makes a big difference to articulation. Consider the ARB limits travel both up and down, so while a longer shock may allow a wheel to drop further, the ARB will still be limiting how much the other wheel can go up relative to it. It's quick and easy to remove one drop link to test this. Removing a drop link is also a good alternative to fitting an ARB disconnect. I've done that many times.
I drove about 30,000 miles with my ARB removed, including lots of towing and carrying stuff on the roof. The compliance over bumps improves noticeably. Body roll increases but not enough to be uncomfortable for regular driving. On dry tarmac the car will still slide when pushed hard. There is an increased tendency to oversteer. I've refitted since welding the front diff, as with the extra traction gained articulation isn't so important. The car is more fun to drive quickly with the ARB fitted, but less comfortable at slower speeds.
I will soon be fitting Gen4 suspension on my Gen3, so it will be interesting to see how that compares.
Forum
Suzuki Jimny
Jimny Chat
Lift kit for Gen.4
Time to create page: 0.105 seconds
