2020 Jimny tuning
- Thank you received: 77
My KTM Duke was like that, l fitted a small fuelling box that gave a slightly richer mixture (around 3% l believe)
The bike was no faster but so much smoother at low RPM
Modern petrol engines often run a leaner than is ideal mixture to get past emissions and l wondered if the Jimny was the same.
- GeorgeC
- Visitor
I was looking for a change to the Alternator/Regulator Voltage Control Computer. He did send me next door to the Auto Electrician, who confirmed there is nothing he can do for me with the electronics. He does sell Lithium Dual Battery/Redarc systems.
- Thank you received: 168
lightning wrote: l am not worried about revving the engine, but it seems almost a bit held back at lower RPM, as if it's being stifled by emissions regulations.
I've found this company: www.quantumtuning.co.uk/car-remap-tuning...e=Suzuki&range=Jimny
I know nothing about them. But they claim 10hp gains from a remap. I'm not sure you'll really that amount more, but a remap would allow anything funky Suzuki have programmed in for emissions control for Type Approval. So I do believe gains can be had.
Personally I've not found the Jimny to be poor at low rpm. It is a small naturally aspirated petrol engine, so it will never be a torque monster. But it will happily pull from 1500rpm in top, maybe even slightly lower revs when on the level.
Really though, to get the performance, you need to use the power band and the gearbox.
If low rpm performance is your desire, then a larger displacement engine and/or boost are the only answers really.
In terms of remaps. My concern would be voiding the warranty on such a new vehicle. But this may not be a concern for yourself.
I'm sure the Jimny's engine would respond to other n/a tuning techniques too, such as a better exhaust system, less restrictive intake or even a cam swap or ported heads. Most should see improvements everywhere, but as a trend, to get more n/a power, you usually move the power curve to the left, i.e. higher rpm use.
An alternative would maybe look at re-gearing. Shorter gearing would keep you higher in the rev band for normal driving. And therefore give you more performance for a given speed in a given gear than you'd have with the stock gearing. Downsides would be, more buzzy engine, potentially lower cruising speeds and a drop in mpg. But if you aren't doing high speed motorway work, this may not matter at all, and may well suit buzzing around country lanes at sub 60mph speeds.
- warrengti
- Visitor
warrengti wrote: I believe the ecu is the same as gsxr 1000 bike they must use the same ecu in a few models.
It won't be the same ECU. It might run similar software or a similar interface. But what it will be controlling and why would be vastly different...
