BigJimnyMeet 2024
radio upgrades
05 Aug 2021 12:07 #237323
by Coco BT
Replied by Coco BT on topic radio upgrades
****kin Legend. Member of the year candidate.
Many thanks
Many thanks
- Thank you received: 320
05 Aug 2021 12:49 #237327
by Gadget
Replied by Gadget on topic radio upgrades
No worries. Only fiddly bit is configuring the multilead, where you have to select a manufacturer specific combination of cutting wire loops and selecting which fly lead to connect to the main harness. Straightforward if you have a stereo from a mainstream manufacturer.
Oh and tip - ground the 'park brake' wire to the chassis of the stereo, it avoids any weirdness where you can't use features of android auto or Apple carplay without the handbrake on.
The following user(s) said Thank You: Coco BT
09 Aug 2021 19:07 #237451
by tim04
Replied by tim04 on topic radio upgrades
Really helpful thread; I’m looking to fit a Pioneer SPH-DA160DAB in my new Jimny Commercial. Apart from the fascia, from connects2, what other leads should I buy? (will it be the same as previously listed on the thread?). I’m also looking to fit a reversing camera…any suggestions on make?
Thanks.
Thanks.
09 Aug 2021 20:31 #237453
by Gadget
Yes, you'll need the leads/adapters mentioned previously, those will allow you to retain use of the steering wheel controls, DAB and FM antenna and the car USB socket.
I don't have any specific camera recommendations, you'll be able to fit any RCA connected camera, so no need for the overpriced Suzuki OEM camera and no adapter needed.
28 Aug 2021 13:58 #237957
by Coco BT
just fitted a pioneer head unit. I think I'm missing a Bluetooth harness/adaptor? as it's not active. DAB is dormant but always was crap, haven't taken it out for a drive yet.
28 Aug 2021 19:38 #237972
by Coco BT
DAB full list of stations has appeared. Still no Bluetooth, I've emailed connections2
28 Aug 2021 20:09 #237973
by tim04
Which Pioneer head unit did you go for? I’m just about to buy one (and adapters) so interested in your experience.
28 Aug 2021 20:47 #237975
by Coco BT
28 Aug 2021 21:17 #237979
by Coco BT
think I know what went wrong, I feel like going outside with a torch lol.
31 Aug 2021 12:37 #238059
by Coco BT
Don't buy the Pioneer. The factory Bluetooth will not work, volume, skip track etc does. I hard wired mine into the glove box and stuck the mic in the A-pillar.
Given the choice, I would go with a Kenwood.
Thank you for your enquiry.
Unfortunately our interface will not retain the OEM (original) Microphone. You will need to use the Microphone provided with the Pioneer radio. As you are fitting a Pioneer radio the Bluetooth you will be using is the Bluetooth on the Pioneer, once the original radio has been removed the OEM (original) Bluetooth Will not longer function.
Best Regards
Best Regards
31 Aug 2021 12:46 #238060
Replied by mlines on topic radio upgrades
Not sure what you mean "Factory Bluetooth will not work". As the factory bluetooth is removed with the exisitng radio this is only to be expected. You will use the Pioneer Bluetooth instead.
31 Aug 2021 13:20 - 31 Aug 2021 13:27 #238061
by Coco BT
it works with the correct harnesses/adaptors, just not with the Pioneer head unit
When you remove the head unit, the Car still retains the Bluetooth functionality, steering wheel controls, built-in mic etc
Last edit: 31 Aug 2021 13:27 by Coco BT.
Time to create page: 0.157 seconds
