Re:torque to weight ratio?
- Andy2640
- Visitor
Ok Busta, you can shoot me too. But that makes 0 sense to me.
EDIT: Aim for my heart please fella's. Make it quick
2018 Jimny auto:allegedly the last "old" auto registered UK.
- AlexK
- Visitor
Andy2640 wrote: You can shoot me if im wrong, but shouldn't it be "send the torque and power down the path of . most, resistance.?
Imagine two hosepipes connected together to look like a T. Water pumped in from the bottom of the T will flow equally out of both sides of the top bar. If you put your finger over one end, the water just flows out of the other open end, since it’s easier for it do that than it is to force your finger away. That’s the path of least resistance.
Torque flows through an axle in exactly the same way as the water. If one wheel is in the air but the other is on the ground, it’s easier to spin the wheel in the air than it is to turn the wheel that’s on the ground, because to do that it has to move the vehicle.
The job of the brake LSD system is to mitigate the default behaviour of open diffs by applying the brake to the spinning wheel until it becomes easier to turn the other wheel instead.
- Thank you received: 1761
What he said ^^^^^^^^^
Andy2640 wrote: "Its always power that is moving things. That's why your car doesn't accelerate through the garage wall when you torque up the wheel nuts"
Ok so, power is the metric of applying force over time. Eg horse power is the amount of time it takes one horse to lift a given mass vertically over a given distance. More horses mean the same mass is moved the same distance in less time or that more mass could be moved by one horse in a greater time.
Torque is the metric of applying force over distance . Eg being able to move a given mass at a given distance hence Newton meters and pounds feet.
I can easily apply the maximum torque that a Jimny motor can directly to a wheel using a socket and breaker bar against a wheel nut but I can't apply that same force over enough time to be able to launch the car through the wall of the garage.
The motor applies its 100 Nm of torque every revolution once it's running and into it's torque curve and I can match that for one rev but the motor also performs upto 6500 revolutions a minute, I have no chance of matching that level of force over that duration.
- Andy2640
- Visitor
Education is a wonderful thing. Great stuff!!
Thanks guys!
