Jimny auto advice needed
- Valleys rambler
- Visitor
- Thank you received: 653
You can leave every thing as was
OR remove the old rotten steel pipe work and just blank off the rubber pipes that's left on
The manual (or freewheeling) hubs allow you to 'switch off' a wheel at a time. If your going onto slippery surfaces, switch them both on before and engage 4x4 as needed. once back to tarmac switch them off for better fuel consumption (stops the wheels turning the shafts needlessly).
The pipes and suchlike can stay, but do blank off any if you remove them. You may get problems with dash lights if theres a leak on it somewhere, so probably best to blank off fully as Jack says
- Valleys rambler
- Visitor
- Valleys rambler
- Visitor
- Valleys rambler
- Visitor
- Thank you received: 225
- Thank you received: 260
Valleys rambler wrote: 2002 model it goes into low on the auto box but not the 4x4 box. The light comes on when I select 4w but 4w is not engaging at all what electrics do I check any diagrams about in here fella
I might be misunderstanding but it seems to me you should forget the auto box selector. Low on the auto is not related to any four wheel drive. The others will give you advice on checking the actual four wheel drive but with it in N (no good in D/P etc. as it locks the tranny) there are checks you can do with it on jacks (not ramps as you have to turn the wheels lol) to see if the four wheels are working as one!!
- Valleys rambler
- Visitor
jackonlyjack wrote: Member j999pre can get new manual hubs around the £100 delivered
Awesome fella bought hubs of Jimnybits should I grease them up or are they ready to go, I fitted them and work OK, need to know if I should grease them tomorrow have to take them back off
- Valleys rambler
- Visitor
- Thank you received: 1761
