Oil or gas??
- Tommy-Boy
- Visitor
So i have owned my little Jimmy for just under a year and overall i love it. It has been great fun to own and maintenance has been very acceptable and easy to do. These cars are so well designed and relatively easy to work on. So after the MOT i have just replaced the front discs and pads along with an offside king pin bearing. This now alows me to start some modification in terms of a lift kit.
I'm looking for a 2" spring kit as cheap as possible. So with a few kits on the market the one think that now stumps me is the 2" oil filled kit. These kits are over £100 cheaper than the pro-comp ones is that for a reson?
Can anyone advise or justify the extra cost for the pro-comp kit?
Cheers
Tommy
Sent from my Nexus 6P using Tapatalk
- Tommy-Boy
- Visitor
IMO..... No. Its for occasional daliy drive and mostly across the feilds and in some mud, so it would be light off road use and rarley up to its guts in mud.
So how are the pro-comp sets justifying the extra money? The cheaper oil kits i'v seen are £280 as opposed to £380, thats a canny diffrence in price?
- TomDK
- Visitor
Pro-Comp shocks may be okay, but they're certainly not what you'd call good quality shock. They're cheap shocks someone has worked out fit with lift springs.
If you just want cheap, go with spring and shock extenders. Then you still retain some sort of decent suspension.
- Thank you received: 1761
Tommy-Boy wrote: Well that depends on the defenition of "thrash"
For that money I would be looking at some decent tyres as they will be a greater improvement for the ability of your car than some cheap and nasty suspension package that will do nothing good for the handling of the car.
- Tommy-Boy
- Visitor
The pro-comp shocks cant be that bad? Alot of poeple use them and they a readily avialable unlike alternatives..... That i'm aware of.
So could standard shocks be fitted, my rear two are shot anyway so will need replacing, with shock spacers and new spacer springs without compromising handeling to get the same result? If so how do you space the front shocks? I'v never seen front spacers before.
Cheers for the input on this fellas. Appreciate it!!
- Tommy-Boy
- Visitor
Whilst i'm sure your right in regards to the quality i just cant justify £500 on a modification to a car that gets used twice a week.
Thanks for the advice but with that in mind dare i ask what you think of this kit on ebay?
Item number 281973398262
(I cant seem to link off my phone)
- wombat
- Visitor
Lifting the suspension will not give you any more ground clearance, the only way to do that is to fit bigger tyres/ and/ or wheels, with all the associated gearing and clearance problems
Tommy-Boy wrote: I agree about buying cheap and buying twice, but jeees that trailmaster kit is over £500.... I didnt even pay that for the car. Lol
You could not pay me to put that on my car.
If the springs are made by a company who supply F1 and wrc then why not name them directly? Surely if the dampers were specific to a Jimny they should not require modifications to the mounting points of the car? Or are they just some with similar fittings that may fit? Then there's the wording of the actual description, I know eBay is not renowned for the literary prowess of its seller descriptions but it's enough to make me wonder what level of service and professionalism I could expect. Also what is the bit about ringing for a discount?
Sorry but I really wouldn't be indulging that. Go to one of the reputable suppliers on here that way you will get a suitable product not just a collection of unbranded and unproven components that may like as not cause some potentially serious issues down the line.
I'm not try to teach you how to suck eggs but if something sounds too good to be true it usually is.
