BigJimnyMeet 2024
alternator squealing
- Decklandpt
- Visitor
02 Mar 2016 14:22 #163256
by Decklandpt
Replied by Decklandpt on topic alternator squealing
@kirkynut, dont think so, the belt is less than a year old. doesn not feel plasticky, and cand feel any wear by running my finger in the tread.
@ back in black, there's no ascertainable wear on the belt, and no rubber dust.
maybe the belt tension needs adjusting, or maybe the crank pulley is on it's way out, i'll check it out this weekend, but i'm dead sure the noise i hear comes from the alternator bearing. as for the squeal, maybe it's the bearing locking up...dunno.
gonna have a look this weekend and send it to my garage next week.
- Back in Black
- Visitor
03 Mar 2016 11:14 #163279
by Back in Black
Replied by Back in Black on topic alternator squealing
Good luck, I hope the issue is the cheapest and easiest fix
It took me a while to work out where the dust was coming from.
03 Mar 2016 17:02 #163296
by kirkynut
Replied by kirkynut on topic alternator squealing
Squirt WD40 in the area of the bearing to see if the noise goes.
- Thank you received: 584
03 Mar 2016 17:18 #163299
by facade
Replied by facade on topic alternator squealing
On mine, the alternator rusted inside, and at startup, the high charging current pulled all the rust flakes into the rotor, and jammed it solid. (Is the theory from the auto electricians who sold me another.) I don't know for sure, as they wont come apart without breaking the casing when they are old.
Switching off, and looking for a problem freed it off for a few days until The Big One, when it stayed seized until I took it off and tried turning it backwards, when it went free.
Probably what helped to write off the front pulley I suppose.
- Decklandpt
- Visitor
03 Mar 2016 18:14 #163302
by Decklandpt
@kirkynut, yeah, that was my first tought, just hope i don´t set it on fire. gonna see if it helps in the weekend.
hard part wil be checking out the rubber in the crank pulley, since it's behind the radiator.
03 Mar 2016 18:19 #163304
That part lists as only for the WagonR+
Replied by mlines on topic Re:alternator squealing
minibbb wrote:
Is this the right part? Seems suspiciously cheap mind you
03 Mar 2016 18:21 #163305
by minibbb
Thanks Martin- that's what happens when you rely on Google!
Ordered the genuine part which was £124 posted. Going to the garage tomorrow but it's annoying as I want to rule the alternator bearing out as the suspect too!
Squealing is horrendous and also the belt is powdering near to the alternator
Replied by minibbb on topic Re:alternator squealing
- Decklandpt
- Visitor
07 Mar 2016 11:02 #163441
by Decklandpt
Replied by Decklandpt on topic Re:alternator squealing
so,had a look in the weekend.
it's definitly the bearing. the crank pulley was fine, no cracks in the rubber bond, and no off-axis spinning
sprayed some wd-40, it helped as long as it was being spayed, but as it was turning it was being spat out, so i turned of the engine, added some more wd-40 and left it to rest, tomorrow i'll drive it to work and see how it goes. do you guys reckon i'll need a new alternator or can the bearing be replaced?
07 Mar 2016 11:44 #163444
by facade
If you can get the alternator apart, you should be able to remove the bearing and match it either from the size, or the numbers on it.
I couldn't get the casing apart, I was sure that it would break, but as you don't want the front bearing, you could warm the casing round the bearing and try.
Of course, you won't be able to drive the car until the alternator is replaced, and you won't be able to exchange it in pieces.
- Decklandpt
- Visitor
08 Mar 2016 13:24 #163496
by Decklandpt
so, drove it to work today, no noises or squealing, guess i'm gonna be carrying that can of wd-40 with me for a week till i go to the mechanic. damn schedules, cant get off work at a decent hour
Time to create page: 0.137 seconds
