- Jimbospanner
- Premium Member
- Thank you received: 9
- Thank you received: 260
Yes it did come with a gasket Rob. I got the paper in case I needed to refit the old stat or reseal the new one. Sometimes these jobs have to be revisited a few times. I also used some gasket sealant. Belts and braces me.kirkynut wrote: Does a thermostat not come with a gasket John?Kirkynut
I finally have the gauge showing (what I call) normal temp at ⅓ into the normal sector. It was interesting to feel the top hose suddenly get hot coolant. Previously it was always lukewarm.
Last summer the gauge never left the cold sector. I tested the old stat and it opened at 62° when it should open at 82°. Not sure if it was actually defective or just that 82° was too low. I know the saucepan test is not a wonderful test. Also this is a cool country and fitting the 88° stat I hope will be a good move. I was toying with blanking off the rad in the winter, the heater was a cooler. but won't need to do that now I hope. Should be a lot better now.
- gusthegorilla
- Thank you received: 190
Now I can fit the T-box I bought off you a couple of years ago, Dave
First-class service, as always, coupled with First Class post, too.....what more could a man ask for ???
Thank you, Dave....always a pleasure.....
Gus
I'm planning to live forever.....so far, so good !!
- Thank you received: 653
Postie was a bit weighed down by this lot!
13500lb winchmax SL with dyneema rope, jimnybits mount (and also rear disc conversion kit, hoses to follow)
And... Winchmax say that yes the freespool leaver casing on the end can be rotated to put the lever on the front instead of the top
- Visitor
- grumyoldjoe
- Elite Member
- Thank you received: 20
Not getting under the car while this crap weather is here, so a job for next week.
Wine improves with age.
- 1066Boy
- Visitor
