so what do guys want ?
- Yellostreak
- Visitor
- Rockwatt
- Visitor
Yellostreak wrote: A jimny version of this....
TORNADO TRAYBACK
We can do you one of those ! When do you want
j999pre wrote: Simple! FLEX!
This! And anything to improve flex and clearance without resorting to big lifts;
Really simple, tough steel bumpers for those of us who don't want winches but want the maximum approach angle.
Radius arm re-location kits to improve clearance (over axle and beside the chassis rather than under it?)
Selectable mechanical lockers that don't need air.
- Yellostreak
- Visitor
TORNADO TRAYBACK
Knew you could got to get some space sorted out and then get a decent rolling chassis or even get you guys to fabricate one.... once I have the space I can set to doing the fit out and electrics/electronics...
I also want to see if I can get around crappy Jimny CVs and to be honest my first thought is to fit Landrover axles ... only because you can ARB them and there are loads available..
- Dave cc
- Visitor
vitara_mad wrote:
Rockwatt wrote:
vitara_mad wrote: affordable diesel conversion kit
What do you mean buy affordable? The reason the kits are expensive is the time consuming machining involved, if I could guarantee to sell say 50 kits and not have ££kkk sat on the shelf for years then maybe I could make some for less but there just not viable for me to make a few at mass produced prices.
And as you know me and how I work ! I make things to a quality not a price so if I did make some they may be expensive but you would know they would work properly don't you
yes I know the quality would be good that's why I asked you a few months ago about the flywheels im still on the case trying to get at least 1 done for me
What flywheel are you after ?
- Flameboi201
- Visitor
Both types of bumpers will be ready soon . Orderd the steel yestetday
- jimothy
- Visitor
- durdle
- Visitor
- Thank you received: 153
jimothy wrote: What about a modified king pin that can be greased. Or has this already been done. Just saves striping it down every time to grease the bearings.
Sorry, it wouldn't work, the kingpin goes through the inner bearing race, there would be no way for the grease to reach the roller bearings. Best to strip and clean and regrease regularly.
- jimothy
- Visitor
- Dave cc
- Visitor
G wagon uses a tin cap under the bearing cup in the axle and another tin cup above the bearing race then the king pin has a hole and grease nipple very simple and very effective so could be done
