Tyre size?
- HiJim
- Visitor
- Monkey
- Visitor
HiJim wrote: hey monkey, im pretty keen on your setup and have a 3 inch lift comming in the mail, im from australia as well, just wondering where u got your wheels from and how much they were? cheers
Hey mate,
My rim's are "Dynamic's" 15x8 -22...they are not the cheapest of steelies...they are about $130 each,but worth the coin cus they are much better quality than the 'cheaper' sunnies. The Dynamic's are also made in AUS
I got the rim's through Perth 4x4....
- Buckley
- Visitor
- Thank you received: 653
Buckley wrote: Hey guys I've got a 3" lift kit on my jimny and got 33" tyres it's great goes anywhere but noticed that it puts a lot of strain on the clutch and engine so I was thinking in putting 31" on, any good places to get good off road tyres and wheels?
do you still have standard transfer box if yes
look into buying a rock lobster
and keep the 33's
- OllieNZ
- Visitor
I'm not sure you trimmed the arches enoughMysticRich wrote: Just fitted 33" on mine today
Attachment not found
- Buckley
- Visitor
- Buckley
- Visitor
Cheers
- Jasonmatthew911
- Visitor
I'm trying to avoid lifting for the first 3 years I have the car, otherwise I will void the guarantee, but I really want to stick wheels out a bit from Guards to add stability and a better look since Jimny is a bit narrow in my opinion...I live in Panama, so it's not ilegal to have tires sticking out beyond guards here...I'd basically like if anyone here knows how big/wide I can get with the New 2019 Suzuki Jimny, without lifting, I can add Spacers if necassary...Hopefully someone can help me out here, thanks.
Also I would expect gearing changes to be needed for those size tyres (new jimny has the same gear ratios as the current one). Body trimming, body lift and suspension lift may also be needed most likley.
215/75r15 or an equivalent wider but no taller is about as much as you can go with standard gearing and still have some performance.
have a look here to compare tyre sizes:
tiresize.com/tyre-size-calculator/
here for gearing comparisons:
www.grimmjeeper.com/gears.html
and here for the gearing specs:
www.bigjimny.com/mediawiki/index.php?tit...erential_information
- Cro5sy
- Visitor
- Cro5sy
- Visitor
