Rear brake shoes replacement
Rear Brake Shoes
This is a job that I have become familiar with as mine eats brake shoes when off-roading. I have recently got as few as 250 miles out of a set and when I had the SJ I managed 29 miles between changes! This is a straight-forward job but a number of people have asked for a guide, so here it is.
So what are the symptoms of worn brake shoes:
  • handbrake doesn't work
  • Grating/Grinding as you brake
  • Poor braking
  • Lots of travel in the brake pedal
Changing the Shoes
  • Assorted screwdrivers
  • Mole grips
Brake shoes
You will need suitable shoes for your car. The BigJimny store sells suitable shoes.
Rear Brake Shoes
If your drums are particularly old and rusty you may want to consider replacing the brake mounting hardware, see suitable shoes
Brake shoe fitting kit
Although not discussed in this article (why not add it yourself, you can edit this article) the process here covers most of the actions needed to replace the rear brake cylinders if they are damaged or leaking. Again these are available in the store, Rear Brake Cylinder.
Rear Brake Cylinder
Changing the shoes
Jimny Rear Drum
Using bolts to remove drum
If the drum is stuck then first of all check that the handbrake is off then insert two small bolts (M8) in the holes in the face of the drum. Reach around the back and feel near the top for a rubber bung. Remove the rubber bung and insert a flat bladed screwdriver. Angle the screwdriver so that the blade is pointing to the back of the car and the handle towards the front, you should be able to feel the adjuster wheel. Using the screwdriver turn the adjuster downwards a few clicks. Then gradually tighten the bolts you inserted in the front, the drum should come off. Do this gradually, tapping the drum as you do it. You should hear the springs/shoes relax and release as you do it. If you do it too quickly you will damage the springs.
Drum removed
With the drum removed the brake shoes can be seen (covered in mud in this case!). Take a really good look at how it comes apart and the position of all the springs and the handbrake adjuster arm as you will need to put it back together correctly later.
Lower spring
Adjuster Spring
Shoe retainer
Now remove the shoes complete with all the springs and adjusters. The shoes are held in by a single spring clip on each side. The clip has a pin through it with a flat end on it. Grip the flat end with a pair of pliers and turn it through 90 degrees. The spring clip and pin should then be released and removed.
Shoe removal
Handbrake cable
Adjuster
With it all stripped down everything should be cleaned down. Make sure that the inside of the drum is cleaned out, if necessary wire brush or emery cloth the surface to clean it up. If a lip has formed around the edge of the drum then file/grind this down as it makes the drum removal difficult. Take the adjuster mechanism apart. Thoroughly clean the threads and ensure that the threads run really smoothly. I normally use a drop of light oil to keep the threads free of rust along with some small dabs of copper grease on any moving parts. It is worth spending some time making sure the adjuster is clean otherwise it will not work.
Removing the Hub
Backplate bolts
Rear axle oil seal
Removing the Bearing
Bearing retainer
Cutting the Bearing retainer
Stuck inner race
Collapsed bearing
The damage to mine is clear!
New bearing
Re-assembly
