Axle mount repairs
Revision as of 20:14, 4 June 2016 by Mlines (talk | contribs)
Repairing the Axle mounts
The axle mounts are a seriously weak point on a Jimny, they are made of very thin metal and are prone to corrosion.
Typical Damage
They can wear out in an "oval" fashion that results in a strange "clunk" noise when letting the clutch up. In the worst case the mount can corrode through and rip away from the axle, this is becoming increasingly common as Jimnys get older.
Worn Axle Mount
Good Axle Mount
They can also completely fail and rip off.
Broken Axle Mount
Wear repair
If the holes have worn oval then a welded repair can be carried out by creating some form of repair piece. You could weld strengthening over the hole or, as I do here, create a washer to fix the hole itself. The internet shows a simple steel washer welded over the hole or the creation of a "top hat washer" I had to measure up to make the washers and the picture below shows the finished item and the template I sent to my friendly engineer to make them with. Yes, the template is simply a 2p coin and 2 x 5p coins – they were the correct dimensions for what I needed with a 12mm hole in the middle.
The section on Removing the arm gives the details on disassembly of the arms themselves.
Template and washers
The trick is to now open out the oval hole in the mounting bracket to the point where the centre part of the washer fits the hole. I simply filed out the hole until the washers fitted. The first picture shows the washer as it should be fitted, whilst the second picture shows the same washer fitted backwards to show how it fits in the hole. I then filed out the other mount so that the other washer fits.
Washer fitted in place
Washer reversed for clarity of fitting
These arms are made with the adjustment built in therefore they should be fitted with STANDARD bushes. They are typically available for 3 inch or 4 inch lifts. Most people feel that 2 inch lifts do not need correction. If you are buying aftermarket arms make sure they provide for vacuum piping, handbrake cables and ABS cables.
Washer welded in place
Replacement repair
This repairs a failed mount with a specialist part, the installation of which requires a high level of welding skills. I sent mine away to be repaired so all I have is pictures of the finished item. The brackets are made by a number of suppliers for welding on
Replacement Axle Brackets
Axle Brackets
Axle Brackets
Axle Brackets
Axle Brackets
Page last edited on 4/06/2016 by user Mlines
