Revision as of 20:55, 10 May 2016 by Mlines (talk | contribs)
Help page
BigJimny Wiki Help Page
What is a Wiki?
Login/Register
This Wiki is linked to the main BigJimny website. If you have registered with the main website then you already have an account and can log straight in.
If you do not have an account then you will be given the option to create one on the main website. This process requires user authentication using a valid email address.
Note: There is currently an issue with the login form that means it does not re-direct back to the Wiki after logging in. You will have to click the link to come back to the Wiki
Formatting your text
A Wiki uses a "Simple Markup Language". When you edit some simple buttons appear at the top of the edit box that gives you some formatting options.
There are more options (not all implemented on this website) here WikI Markup Language
