Battery
Revision as of 14:24, 26 February 2019 by Bosanek (talk | contribs) (Reprocessed the article to clearly indicate which content refers to Jimnys gen3 and which refers to Jimnys gen4)
The purpose of this article is to give insight about issues and solutions regarding battery usage in Jimnys.
Standard battery in petrol Jimny 3
  • The standard battery type, as fitted to all petrol versions of the Jimny 3 from 1998 to 2018 is an 054.
  • The dimensions are 196L x 127W x 223H.
  • The terminals are Japanese post type with the positive terminal to the right of the negative as you hold the battery with the terminals closest to you.
  • The 054 is a common battery type used on many small Japanese and Korean cars.
  • It is readily available from car battery suppliers and typically inexpensive.
  • The performance of batteries varies between manufacturers.
  • Typically the lowest performing 054 batteries have a capacity of 30 Ah and CCA rating of around 260 A.
  • This adequately meets the standard electrical load requirements for the Jimny in a "normal climate".
  • There are higher performing batteries of this size, up to approx. 45 Ah and approx. CCA rating of 400 A.
    • Higher performing batteries are even officially recommended by Suzuki (in the owner's manual) for "cold climates".
Standard battery in diesel (DDiS) Jimny 3
  • Diesel (DDiS) Jimnys 3 use much larger and more powerful battery as standard.
  • The size of factory battery in DDiS Jimnys 3 is approx 225L x 175W x 220H.
  • Capacity in this size ranges from 60 Ah to 80 Ah, and CCA rating from approx. 550 A to 750 A.
    • The colder the climate, the more powerful battery should be used.
  • This kind of battery should provide sufficient power of high power loads like winching.
    • Note that there is no space in the engine bay of DDiS Jimnys 3 for an additional battery.
Standard battery in Jimny 4
Info needed...
Solutions for higher battery requirements in petrol Jimny 3
  • In situations where higher electrical output may be regularly required (sustained winching for example), much higher spec or larger batteries should be considered.
  • In petrol Jimny 3, the standard battery tray in the engine bay can accommodate a slightly larger battery.
  • Aftermarket battery trays that mount in the nearside of the engine bay offer the ability to fit a single large battery or to run a twin battery system.
Solutions for higher battery requirements in Jimny 4
Info needed ...
Page last edited on 26/02/2019 by user Bosanek
