Jump to navigation
Jump to search
Changing the Brake Pads is a simple and quick job within the grasp of most people's abilities.
The symptoms of worn brake pads:
- Poor braking
- Pulling to one side
- Squealing and judder when braking
- Assorted screwdrivers
- Circlip pliers (External)
- A G-Clamp or piston retraction tool
Removing the Caliper and pads
- This then reveals the brake caliper, this is the passenger side (nearside) caliper (UK) .
- Here are the new pads compared with the old.
- Note that ADK84224 are an aftermarket equivalent of the Suzuki part.
- New pads, are available in the BigJimny Store.
- The old are worn down to the metal.
- The new pads then simply push into place held by the spring clips.
- Place the anti-squeal shims in place.
- Smear a bit of Copper Grease on the rear of the shims to help reduce squeal.
- Now the Piston has to be moved back.
- I use a G-Clamp and wind the piston back in until it is flush.
- Pay attention to your brake fluid reservoir during compression as this will drive brake fluid back through the lines and can cause your reservoir to overflow.
- Now swing the caliper back into position and bolt up the caliper bolt.
Page last edited on 21/01/2018 by user Bosanek
