Jump to navigation
Jump to search
The purpose of this article is to give insight about issues and solutions regarding battery usage in Jimnys.
Standard battery in petrol Jimny 3
- The standard battery type, as fitted to all petrol versions of the Jimny 3 from 1998 to 2018 is an 054 (British sizing standard).
- The dimensions are 196L x 127W x 227H.
- Some other sources claim the length of 054 batteries to be 187 mm.
- In general case anyway, there is certainly at least +-5 mm tolerance in sizing when dealing with car batteries.
- The terminals are the relatively small Japanese (JIS) post type with the positive (+) terminal to the left of the negative (-) as you hold the battery with the terminals closest to you.
- The British sizing 054 is a common battery type used on many small Japanese and Korean cars.
- It is readily available from car battery suppliers and typically inexpensive.
- The performance of batteries varies between manufacturers.
- Typically the lowest performing 054 batteries have a capacity of 30 Ah and CCA EN rating of around 260 A.
- This adequately meets the standard electrical load requirements for the Jimny in a "normal climate".
- There are higher performing batteries of this size, up to approx. 45 Ah and approx. CCA EN rating of 400 A.
- Higher performing batteries are even officially recommended by Suzuki (in the owner's manual) for "cold climates".
Standard battery in diesel (DDiS) Jimny 3
- Diesel (DDiS) Jimnys 3 use much larger and more powerful battery as standard.
- The size of factory battery in DDiS Jimnys 3 is approx 225L x 175W x 220H.
- Capacity in this size ranges at 60-80 Ah, and CCA rating at approx. 550-750 A.
- The colder the climate, the more powerful battery should be used.
- This kind of battery should provide sufficient power of high power loads like winching.
- Note that there is no space in the engine bay of DDiS Jimnys 3 for an additional battery.
Standard battery in Jimny 4
Info needed...
Solutions for higher battery requirements in Jimnys
- In situations where higher electrical output may be regularly required, much higher spec or larger batteries should be considered.
- Bear in mind that larger capacity and / or CCA rating generally implies a heavier battery.
- Examples of requirements for higher electrical output:
- Sustained winching;
- In-cabin dash camera(s) with parking recording functionality, where the vehicle is driven relatively rarely (days between runs);
- Remote "motorhome"-style camping in the wilderness;
Solutions in petrol Jimny 3
- In petrol Jimny 3, the standard battery tray in the engine bay can accommodate a slightly larger battery.
- Batteries with dimensions of 236L x 127W x 227H (British sizing code 155) have been used in Jimnys 3 without any fitment issues.
- Such batteries usually have capacity in the range of 45-55 Ah and CCA EN rating 400-500 A.
- Aftermarket battery trays that mount in the nearside of the engine bay offer the ability to fit a single large battery or to run a twin battery system.
- There is an interesting forum topic 1 in an external forum in South African Republic.
Solutions in petrol Jimny 4
Info needed ...
Page last edited on 18/07/2022 by user Bosanek
