Isofix seat mounts
All Jimnys 3, produced for the European market sometime since 2012/2013 until the end of production in 2018, have rear seat isofix anchors only because it became mandatory by European Union. As far as it is known, no Jimny 3 had such anchors in Europe prior to that year. There is no data about the presence of isofix rear seat anchors in Jimnys 3 in other world markets.
All Jimnys 4 have rear isofix seat anchors.
Apart from the standard role of better securing a child seat to the vehicle compared to the classic method of using a seat belt, isofix seat anchors have additional potential:
  • Some portable car refrigerators and other devices can use isofix seat mounts for much better fixation in a vehicle.
  • The isofix anchors can be used as additional tethering / securing / welding points for various modifications inside the cabin if the vehicle is being modified for some utilitarian use.
Jimnys 3 with and without isofix
There are only two differences between Jimnys 3 which have and which don't have rear seat isofix anchors:
  1. There is a rectangular vertical hole in the middle of the rear side of each rear seat's backrest, and there is a short horizontal metal rod in the middle of each hole;
    • These holes are obviously visible when the rear seats are viewed from behind (from inside the boot / trunk).
      • Searching for them is the easiest way to determine if a Jimny 3 has isofix rear seat anchors or not.
    • These holes are used as additional ("top tethering") points by some (but not all) isofix-compatible child seats, refrigerators etc.
  2. There are four rectangular metal hooks welded to the vehicle's floor just below the upper (back rest) part of the rear seats - two below each upper part.
    • These hooks are hidden and are invisible until the rear seats are removed.
    • You can feel them if you search for them with your fingers between the upper and lower part of the rear seat.
    • Most isofix-compatible child seats, refridgerators etc. connect / hook onto these floor hooks, and that is what gives them the stability.
Practical notes about using isofix
  • Do not assume that any isofix-compatible seat or object is compatible with any isofix-equipped vehicle, as that is not guaranteed by the standard!
  • This is especially valid for Jimnys, as their interior space is quite constrained (especially in the rear part of the cabin).
    • This means that there are almost no options nor much room for any adjustments when placing a child seat or a refrigerator on Jimny's rear seats.
      • If an object does not fit properly in a Jimny for some reason, you are usually sh** outt'a luck with that product.
  • Therefore, before buying an isofix-compatible product to use in your isofix-equipped Jimny, check with the product's manufacturer if the product is officially compatible with your Jimny generation.
  • The best method is to test the fitment in practice before committing to buy the product.
List of tested compatible products for Jimny 3
Chipolino Techno 360 child seat
  • Tested and used daily by forum user Bosanek.
  • Fully rotatable (front / side / rear facing) and fully adjustable to any child's age / weight / height.
  • The rotation feature is useless in Jimnys - there is no space to rotate the seat in place once installed in the vehicle.
    • However, once the seat is set in the rear or the front facing mode outside of the car, it fits in the car just fine.
    • Rear facing mode is the recommended usage mode, as long as the child is small enough to fit in regarding the leg room.
  • Capability to be used in rear facing mode for children weighing up to 18 kg.
    • This is a relatively rare feature, as the majority of rear facing child seats on the market accommodate children only up to 13 kg.
  • The seat can be used with any anchoring combination:
    1. Dual ISOFIX anchoring (lower + top tether) + seat belt;
    2. Only lower ISOFIX + seat belt;
    3. Only top ISOFIX + seat belt;
    4. Only seat belt;
  • Therefore, this seat is compatible even with older non-ISOFIX equipped Jimnys 3, where it can be used in the "only seat belt" anchoring mode.
    • Of course, this anchoring mode is not as secure as the ISOFIX mode, but Jimny is not a very safe vehicle to be driven in anyway.
Installation examples in Jimny 3
Example 1
Below is an example of an isofix-compatible child seat base which could not be installed in an isofix-equipped Jimny 3 because the base's isofix connecting rods are too short.
Installation examples in Jimny 4
Example 1
Add your own ....
Page last edited on 12/08/2021 by user Bosanek
