green turtle
- vdl
- Visitor
06 Aug 2014 10:11 #121420
by vdl
green turtle was created by vdl
- Goniu
- Visitor
06 Aug 2014 12:41 #121423
by Goniu
Replied by Goniu on topic green turtle
Hi and welcome! Nice turtle indeed
- Tadpole
- Visitor
06 Aug 2014 18:57 #121440
by Tadpole
Replied by Tadpole on topic green turtle
Mmmm looks like you are busy ..............
- vdl
- Visitor
09 Aug 2014 19:45 #121647
by vdl
Replied by vdl on topic green turtle
- vdl
- Visitor
17 Aug 2014 13:56 - 17 Aug 2014 13:58 #122242
by vdl
Last edit: 17 Aug 2014 13:58 by vdl.
- vdl
- Visitor
23 Sep 2014 05:10 - 23 Sep 2014 06:05 #124839
by vdl
got turtle in garage
rear axle done
front axle welded
exedy clutch in
gearbox fitted - need to bolt in
140A alternator - from opel/vauxhall
got 4.16 box from rockwatt
finally got rear sidegears for front diff/larger cv's
rear axle done
front axle welded
exedy clutch in
Last edit: 23 Sep 2014 06:05 by vdl.
- vdl
- Visitor
23 Sep 2014 18:03 #124880
by vdl
gearbox bolted
engine starts and runs
alternator giving ~14.6V - nice
rear sidegears in front diff
- vdl
- Visitor
23 Sep 2014 19:58 #124892
by vdl
if anyone wants to know about alternator - bosch "0 124 525 030"
really tight fit - almost touching engine mount
belt 4PK0884
belt 4PK0884
- lindsay
- Visitor
23 Sep 2014 21:25 #124909
by lindsay
Replied by lindsay on topic Re:green turtle
Hey looks like a nice build, what amp is alt? Does it bolt straight in?
Btw I am running rs shafts and cvs and there spot on, touch wood
- vdl
- Visitor
23 Sep 2014 21:34 #124910
by vdl
Replied by vdl on topic Re:green turtle
140A
jimny mounts were a bit modified to fit it
i'll take photos tomorrow
- vdl
- Visitor
24 Sep 2014 18:29 #124977
by vdl
radiator back in
front axle ( still empty ) in place with springs and shocks and arms attached
front diff assembled
alternator pics
upper mount needs offset
lower mount needs longer bolt
it goes through first mount ( offseted ~11mm to the radiator and trimmed so bolt don't mess with belt )
then through distancer
then uses original mount and thread - bolts through and goes into second alternator mount
if you use longer bolt then you can finish with nut to more secure alternator in place
alternator pics
- vdl
- Visitor
12 Oct 2014 16:31 #126299
by vdl
front diff in
one side done - halfshaft, kingpin, etc
also trimmed hub nut to fit hubs without spacer
seems than boggers are still touching body at max - hammer or cutting/welding will help
rockwatt transfer box in place
waiting for rs to send right longer halfshaft
