Re:Jimny Gen 4 Diff Breathers?
- lookonimages
- Thank you received: 64
- Thank you received: 80
Does it need differential breathers, are they not fitted as standard?
I had mine done recently. Otherwise the wading depth is something ridiculous like 30cms from memory.
- lookonimages
They are fitted as std but sit above the axle. This set move them higher to enable you to go through deeper water as end point is high in engine bay.lightning wrote: Looks a nice kit but,
Std you cand wade through 30cm water or it will suck in water if water is higher then breather point
Diff oil an water is not friends.
So most people that do a little more adventurous stuff lift the end cap much higher by rooting it to highest point in engine bay. More likely you then can easlily go through 4 feets of water.
The realexperts take it upinto in snorkel and can go throuģh 5feet
l may order a kit for ours.
- Roger Fairclough
- Thank you received: 210
Roger
- RumbleAndSway
- Premium Member
- Thank you received: 12
Couple of tips:
A ramp and “diff cap removal tool” will make the fitting process so much easier. Without these it would have defeated me.
If the kit any good? Too early to tell but first impression is one of delight. Addresses the only real flaw in the JB74 - wading depth.
Let’s see if the connections hold up.
- Roger Fairclough
From memory, lambert has said that he doesn't wade deeper than the depth of a tyre ie approx. 5".
Fitting diff. breathers will help to protect your diffs. but to protect the lot you need further work.
Roger
- Thank you received: 1801
Fitted the Des-Sol breather kit today.
Couple of tips:
If you are regularly going to be in deep water then you have to accept significant shortening of the service life of every component that you partially submerged. I personally resist getting the bottom of my wheel rims under water others draw their lines somewhat higher. And that's before you decide on how dirty the water you are prepared to play in is. Clean flowing mountain runoff is very different to silted muddy holes on a pay to play site. The worse the environment you use it in the more you need to look after it.
- Thank you received: 458
So far, like Lambert I haven’t been over the wheel rims, but with BigJimny coming up and I intend to join a local club I can see I might be going through a bigger puddle from time to time.
So should I fit a breather kit?
Which one to go for (in the UK)?
Are there any downsides?
Robin
- Thank you received: 552
Stay out of deep water unless you have built a 100% off road use vehicle, it will damage things.
- RumbleAndSway
- Premium Member
Winter 2023/24 delivered a number of weather events and regular flooding on my bi-weekly Guildford to Brighton commute. Nothing crazy but 10cm-20+cm of standing water in places.
A journey I usually make in other cars but on these occasions I use the Jimny.
Only concern was the vulnerability of the standard diff and TC breather caps.
Snorkel [OTT] and breather upgrades offer additional peace of mind.
I will not be forging rivers.
Thanks again.
