BigJimnyMeet 2024
Windscreen seal failure
- Thank you received: 71
18 Feb 2024 17:29 - 18 Feb 2024 17:29 #254422
by lightning
Replied by lightning on topic Windscreen seal failure
Well, as nobody's ever reported this issue, maybe Bert on the Jimny assembly line (windscreen station) forgot to bond your plastic pieces on properly, because he was distracted by Emily on "wheel arch trim" across the hall, who he's fancied for months.
Last edit: 18 Feb 2024 17:29 by lightning.
The following user(s) said Thank You: DrRobin
- Roger Fairclough
- Thank you received: 194
18 Feb 2024 17:39 #254423
by Roger Fairclough
Replied by Roger Fairclough on topic Windscreen seal failure
There is a 12 year anti corrosion warranty, but any mods. to your warranty gives Suzuki the right to reject the claim. From memory it's clause 6.
Roger
Roger
- Roger Fairclough
18 Feb 2024 17:42 #254424
by Roger Fairclough
- Thank you received: 479
18 Feb 2024 17:45 #254425
Replied by Soeley on topic Windscreen seal failure
Looks like it has happened to 3 other people on this private Facebook group www.facebook.com/share/p/9HtvkHVbk42t9ate/
- Thank you received: 168
18 Feb 2024 17:50 #254428
by 300bhpton
Replied by 300bhpton on topic Windscreen seal failure
99.99% sure they use a pressure washer as I watched them washing another vehicle in the wash area when I picked mine up.This is a manufacturing problem, not a washing technique issue. We appear to be preparing the gallows for the poor person that washed a car......
We don't even know if they used a pressure washer, it could simply be time, rain and wind pressure, the stuff the front of a vehicle should survive.
18 Feb 2024 18:03 - 18 Feb 2024 18:03 #254432
by jlines
Replied by jlines on topic Windscreen seal failure
In that group I see someone else said they think it happened because they pressure washed the car too hard so would seem the likely cause but not one you could prove once you’ve driven the car away from the dealer. The other week whilst washing my lcv I noticed a scratch on the wheel arch just a couple of days after it had been to the dealer. Now it could have been anything from someone walking past it at my work or on my driveway, myself when cleaning although I’m very cautious in what I do using new cloths etc or could have been the dealer. Sadly you just can’t prove it or accuse anyone.
Last edit: 18 Feb 2024 18:03 by jlines.
18 Feb 2024 19:49 #254439
When I have a courtesy car, I have to walk round it and sign to say there is no damage. Same thing should be done for your own car when dropping it off.
11 Mar 2024 16:05 #255007
by slaw
Replied by slaw on topic Windscreen seal failure
the rubber strip that's come loose is used to regulate the depth of the glue when been fitted and no longer has any use, so you can pull it out and forget about it, it is likely to have been dislodged by a pressure washer,
mlines drawing show items 3, 4, 5 & 6 all do this job, and items 2 are "gravity stops" ensuring the screen is located correctly and doesn't slide down while the glue is curing,
i hope this puts your mind at rest
regards
andy
regards
andy
- Thank you received: 372
11 Mar 2024 16:31 #255008
Replied by DrRobin on topic Windscreen seal failure
I am not sure I would remove it, you might end up with a whistling windscreen and anyway it will only fill up with muck.
Suzuki clearly leave it in for a reason, if not they would have removed it at manufacture.
11 Mar 2024 20:34 #255022
by slaw
it's certainly not doing any harm sitting there. i had assumed it would be flapping about and possibly causing wind noise now no longer stuck in place,
Time to create page: 0.141 seconds
