Re:Better tyres for road use?
- Thank you received: 79
23 Jul 2023 11:49 - 23 Jul 2023 11:51 #249965
by lightning
Better tyres for road use? was created by lightning
Can someone recommend better tyres for road use on our 2020 Jimny?
The standard fit tyres are okay in the dry, but in the wet they are death traps.
After the third stability control intervention in a week, under normal driving, l want to fit some tyres that actually grip a wet road.
l guess it's partially because on road it's a lightweight RWD vehicle with a relatively high C of G
But on corners it just wants to go straight on. The tyres have done 15,000 miles and still look okay (plenty of tread)
Last edit: 23 Jul 2023 11:51 by lightning.
- Roger Fairclough
- Thank you received: 210
23 Jul 2023 12:01 #249966
by Roger Fairclough
Replied by Roger Fairclough on topic Better tyres for road use?
What tyres has your Jimny been fitted with?
Roger
Roger
23 Jul 2023 13:41 #249967
by lightning
Replied by lightning on topic Better tyres for road use?
They are the original fitment Bridgestone Dueler H/T
- Thank you received: 600
23 Jul 2023 13:45 #249968
by facade
Replied by facade on topic Better tyres for road use?
Not much help, but mine is on the standard Bridgestones and they are perfectly fine in the wet (but I was a bit annoyed that they don't have the mountain symbol on the side).
However they do have "Made in Japan" on them, I recall there being some suggestion with the Gen 3 that you could get Bridgestones that weren't made in Japan, and they had negligible grip in the wet.
- Thank you received: 656
23 Jul 2023 14:25 #249970
Replied by jackonlyjack on topic Better tyres for road use?
I would say go for 215/75/15 these will be 10mm taller than 195's fitted
something like these E rated for wet and fuel
Toyo Open Country A/T
ebay item number 313879715622
- Thank you received: 1797
23 Jul 2023 15:25 #249971
Replied by Lambert on topic Better tyres for road use?
Agreed Spanish duelers are nasty in the wet. Japanese are better but still easily upset by a puddle. I don't know if the size you need is available but my radar renegade at5's are about 2/3's the price and yet vastly superior in all conditions.
- Roger Fairclough
23 Jul 2023 18:49 #249972
by Roger Fairclough
Tonka has the same "made in Japan" tyres and I don't have a problem with them wet or dry.
The comment about them being "upset" by a puddle" is fundamental to a rear wheel drive car. I found a deep puddle and drove through first in rear drive only and then in 4 wheel drive. The extra stability was very reassuring.
Roger
Roger
23 Jul 2023 20:24 #249973
by Grizzlie
Replied by Grizzlie on topic Better tyres for road use?
I'm actually quite happy with the Grandtrek AT20's that came stock on mine. And really impressed with their offroad capabilities.
- Thank you received: 175
24 Jul 2023 08:44 #249976
by 300bhpton
I found the factory fitted tyre exceeding expectations in most scenarios. Never had mine slide or skid on a wet road.
Never had the ABS kick in either. I also drive it pretty hard on road.
I'm on some AT's now, but did 5000-6000 miles on the original tyres. When I bought the Jimny it was a wet winter and drove the first few thousand miles in almost non stop rain, bit of light snow and flooded roads.
Replied by 300bhpton on topic Better tyres for road use?
I find this highly surprising. Are you 100% sure it is the tyres?Can someone recommend better tyres for road use on our 2020 Jimny?
- Thank you received: 403
24 Jul 2023 09:27 #249977
Replied by yakuza on topic Better tyres for road use?
It varies from year to year how good the UV resistance is in the tires and how much UV radiation they get. That make the rubber hard and less grippy.
24 Jul 2023 09:29 #249978
by 300bhpton
Be interesting to know from the op if this is a new issue or one that has always existed. 3 years and 15,000 miles in the UK is not really very much for a tyre though. Esp if you aren't a hard driver.It varies from year to year how good the UV resistance is in the tires and how much UV radiation they get. That make the rubber hard and less grippy.
24 Jul 2023 10:12 #249979
by 300bhpton
As for better road tyres, you could look at a more road biased tread pattern.
I've not used these, but they look very 'on road' biased:
www.blackcircles.com/catalogue/uniroyal/...H/96/f?tyre=27243404
If you go up a size there is a B rated for wet weather, although it is a van tyre:
www.blackcircles.com/catalogue/triangle/.../100/f?tyre=43007761
Interestingly the factory tyre is C rated for wet weather, which seems on par with all the offerings really.
Of course road biased tyres will not be as good off road, more vulnerable and less good in the snow too.
Other options if you want more sporty or road orientated would be to look for a non 4x4 tyre fitment. But to retain 15" rims would result in a shorter tyre, so even less good off road, would probably impact ride and gearing.
A 205/55R15 should have road biased choices.
If you want to retain the tyre diameter and more roady tyres, you might need to look at different rims. I'd guess a 17" rim would offer a better choice of tyres to give the same rolling radius.
Time to create page: 0.209 seconds
