BigJimnyMeet 2024
Re:Gen 4. Conversion to 4 seats
05 Jan 2023 20:07 #246704
by Artie
Gen 4. Conversion to 4 seats was created by Artie
I found this on You Tube if anyone is interested. Woodstock Car Sales Gen4. Conversion to 4 seats.
07 Jan 2023 06:54 #246739
by Motacilla
Replied by Motacilla on topic Gen 4. Conversion to 4 seats
Very interesting! I was surprised when they said at the end of the video that they could do the conversion in one day -- I would have assumed that there was some welding required (with associated paintwork etc).
Here's the link for those interested. Not my kind of thing but I could definitely see a market for it.
07 Jan 2023 08:57 - 07 Jan 2023 09:34 #246741
Replied by mlines on topic Re:Gen 4. Conversion to 4 seats
In my opinion it seems a bit of a kludge. It does not fully reproduce the actual Jimny installation. They do not solve the curtain airbags issue, the side impact strengthening and and seat belt pre-tensioners. In the picture the seat belt spools are connected to the seat mountings rather than the factory positions within the rear pillar. So it is basically a bolt in complete rear seat unit only
So it is a solution and no one has come up with a solution before. I would check with your insurer before fitting
Sent from my moto g42 using Tapatalk
Last edit: 07 Jan 2023 09:34 by mlines.
- Roger Fairclough
- Thank you received: 194
07 Jan 2023 13:41 #246744
by Roger Fairclough
Replied by Roger Fairclough on topic Re:Gen 4. Conversion to 4 seats
Also as you are converting a van into a passenger vehicle, I imagine you would need to advise the DVLA of the work that has been done and then they will advise you as to the tests required to conform with current legislation regarding seat and seat belt mountings as well as problems with your insurance company. This could turn out to be a bit of a minefield.
Roger
Roger
- Thank you received: 70
07 Jan 2023 15:17 #246746
by lightning
Replied by lightning on topic Re:Gen 4. Conversion to 4 seats
Probably cheaper to sell your Jimny Commercial and buy a used SZ4
The SZ4 s a fair bit cheaper to buy used as most want the SZ5 but it's very similar to the Commercial
- Grima
- Visitor
07 Jan 2023 17:47 #246749
by Grima
Replied by Grima on topic Re:Gen 4. Conversion to 4 seats
How MAD is this !!!!!!!!!!
Read GOV.UK, reg's on fitting rear seats in a van. You don't need to fit rear seat belts. (unless there under 12 years old.) So no need for air bags or side impact protection.
It's all in black & white on the GOV / DVLA web site.
Happy Reading.
Happy Reading.
07 Jan 2023 18:28 #246750
Its not mad.
You are correct, it is legal.
However a Jimny is small in the rear so it is likely to be used for children , not adults. Indeed, the conversion states it is ISOFix compliant.
People should be aware that it is built to a different specification to the factory build which will be particularly relevant when it is sold on again to a more unsuspecting owner.
08 Jan 2023 12:49 #246762
by Motacilla
Replied by Motacilla on topic Re:Gen 4. Conversion to 4 seats
The Isofix thing was another surprise to me, as I thought that required welded lands/hooks (what do you call them) but this installation is apparently not welded. Or is it? Perhaps the person with the conversion will join the group. I suspect there's only one so far, the video that Artie posted only went up just before the holiday.
Maybe Woodstock's will become a site co sponsor and will come here to tell us all about it.
08 Jan 2023 14:15 #246763
ISOFix is built into the seat frame and then the seat frame is bolted to the floor which is pretty much standard on all cars nowadays. As standard there is a bolt hole missing on the LCV which is probably remedied with a hole being drilled and a strengthening plate fitted ( although the "genuine Suzuki" fix would be changing the underfloor cross member for the SZ5 version)
08 Jan 2023 20:57 #246767
by lightning
As my previous comment which was skipped over
Do it properly
lf you want rear seats sell your Jimny Commercial and buy an SZ4 or SZ5?
Do it properly
09 Jan 2023 10:01 #246771
by Motacilla
09 Jan 2023 11:36 #246772
I think you are correct with the Suzuki factory seats, But it is very common for the seat frame to have them built in
