GEN 4 Seat Belt fraying
- Thank you received: 552
Just an option if Suzuki don't want to cover it under warranty.
- Thank you received: 1761
- GeorgeC
- Visitor
If the articulation of the mount is restricted, then this may be the cause and should be warranty. Seat belt operation and retraction is checked on warranty services.
- Roger Fairclough
- Thank you received: 194
Does anyone else find it mildly alarming hat Suzuki don't have these parts in the country?
- Roger Fairclough
Roger
- GeorgeC
- Visitor
Thanks for the location confirmation. That suggests a couple of options.Micheal wrote: Thanks Roger and all other commentators. To answer one question, the frayed bit on the belt is situated just below the shoulder when the seat belt is fastened. I can only imagine there was some manufacturing flaw with this belt and it had a small tear which became worse being pulled through the mounting bracket. I haven't taken the plastic cap off yet, will wait until Suzuki respond to the dealer sending them pics.
One, when the seat belt is retracting it gets fouled in the retractor mechanism behind the panel.
The other, you may have had a resident rodent living behind panel, check that the drain plug for that area is intact, its just behind the right hand rear wheel, I'll attach a photo below.
I'll update you all when I've heard what Suzuki have to say.
No explanation provided. Basically a 'get this off my desk' special.
- Thank you received: 71
- Roger Fairclough
This leaves faulty manufacture, which is extremely unlikely, or a fault during use. If there is a sharp object within the area that the belt is pulled through I would expect the belt to show damage along the section in question ie. it would not just occur in one place. This, to me, would suggest that the driver is wearing something that is catching on the belt when the car is driven. We know that the frayed area is in the vicinity of the drivers shoulder so I suggest the investigation checks this area. A metal object, a stud or zip or even a button could be the culprit. If you just buy a new one and the same thing happens again, then the dealer will just say it must be the way it is driven because there is no proof that it is belt failure.
Roger
