Re:What did the postman bring today
- Thank you received: 426
03 Nov 2020 21:23 #229664
Too late had to open the package to see the masks
- Roger Fairclough
- Thank you received: 153
03 Nov 2020 22:17 #229668
by Roger Fairclough
Replied by Roger Fairclough on topic What did the postman bring today
Oh that was sneaky!
14 day quarantine for you my lad.
- Roger Fairclough
05 Nov 2020 13:32 #229710
by Roger Fairclough
I have been messing about. Picture one is the heat exchanger which I fitted into the heater hose. It is plumbed into the windscreen washer hoses to supply warm water to the screen.
Three 50mm instruments, voltage, water temperature and oil pressure.
This is the thermo-coupling fitted into the top rad hose.
This is the storage box fitted between the seats to compensate for loss of the small box where the new instruments go.
Roger
Roger
05 Nov 2020 18:22 #229722
Nice, I love analogue gauges, had a few fitted in my Mini and two in my last car.
- Thank you received: 79
07 Nov 2020 16:55 #229781
by Foxtrot
Replied by Foxtrot on topic What did the postman bring today
14 Nov 2020 18:55 #230042
by Sergiu
Replied by Sergiu on topic What did the postman bring today
- lookonimages
- Away
- Thank you received: 57
26 Nov 2020 10:46 #230414
by lookonimages
Replied by lookonimages on topic Re:What did the postman bring today
- Thank you received: 214
10 Dec 2020 14:57 - 10 Dec 2020 14:59 #230827
2011 Blue Jimny SZ3, Hankook Dynapro/Maxxis Worm-Drive, BB Classics BB6 Sports Seats, Radius Arm protectors, Android Head, DAB, 360 Camera, TPMS, K&N, Bosch Aerotwin, boot light, parcel shelf, boot box, dash box, Osram Nightbreakers, CTEK Battery Sense, Front & Rear Recovery points, CB Radio.
Replied by DrRobin on topic Re:What did the postman bring today
I am probably not alone, but in lockdown and not using my Jimny much the battery has gone flat twice. I saw this Bluetooth battery monitor from CTEK, called Battery Sense, it stays connected to the battery and constantly measures battery voltage and temperature, then connects to your phone with Bluetooth.
They are not cheap, but what I like about it is that you can have multiple batteries reporting to the same app and as I have two currently under used cars I now have both in the one app. You get the current state and a graph of data, the units store 7 days worth, so plenty of stats to keep you amused on dark nights.
The Bluetooth is good enough to get both cars from the front room, great to avoid a flat battery when you want to use your car. They also market them for motorbikes, I might get one for my old Triumph when it goes back on the road as bike batteries are always going flat due to the small size.
Last edit: 10 Dec 2020 14:59 by DrRobin.
- Thank you received: 1629
13 Mar 2021 13:56 - 13 Mar 2021 13:58 #233709
Replied by Lambert on topic Re:What did the postman bring today
Today I got my replacement/continuation service book from our illustrious leader Martin. My original one only went upto 108k but the new one goes to 144k. So between them I have a quarter of a million miles. So enough for about the first 10 days after lockdown is lifted, I want to go for a drive without any destination so badly!
Last edit: 13 Mar 2021 13:58 by Lambert.
- Thank you received: 480
01 Apr 2021 17:11 - 01 Apr 2021 17:16 #234167
by Scimike
Replied by Scimike on topic What did the postman bring today
If you are oil brand driven look away now and remember that all oil irrespective of the badge come from the same hole in the ground.
Still with me, then read on.
I tend to change the oil at half the recommended service intervals, in my opinion clean oil is better than dirty. However since I stopped working for Halfrauds I no longer benefit from colleague discount, so the normal Castrol etc has started to get expensive. So I searched for an alternative and it arrived today, less than 24 hours after I ordered it. It's Mannol oil, a German automotive brand blended in Lithuania by SCT.de. It gets good reviews and meets the highest spec required by the G3 Suzuki jimny (fully synthetic API SL), although like most they do produce higher (SN, ACEA A5 and C1 to C5) for all those picky modern engines with stringent emission control systems.
It's a good price at £35.99 including delivery for 20ltr, so that's £7.20 a service (4ltr), £15 with OEM filter !
It will be another 4000 miles before I am due the next service and I will report back on if the engine sounds any different on cheap none brand oil. If it does not I will continue to use it, if it does my Land Rover canburnuse it
Well it's time to report back after using this cheaper oil.......It's fine, engine is happy and sounds no different, wallet is happy. Recommended for those that are not brand loyal.
Last edit: 01 Apr 2021 17:16 by Scimike.
01 Apr 2021 17:43 #234168
Good to know. I use which ever c3 is available in bulk locally. I use c3 on the basis that with my typical annual mileage over specified oil is a reasonable option. Oil is cheaper than engines.
03 Jun 2021 18:59 #235593
Finally got the mudflaps from China only ordered on the 12th of May. Job for Saturday morning.
Time to create page: 0.477 seconds
