Starter motor tech
26 Jul 2024 08:50 #256936 by lesgrandepotato
I’m seeming to be getting through starter motors quicker than I would hope….
I’ve added in a relay, so now I get the stuck starter click with much vengeance.
I suspect it’s water and muck causing issues.
Has anyone seperated the bendix firing from the current being tripped in? Considering adding a remote solenoid. That should at least shock a stuck starter free if it is full of cack.
I can’t be the only one with a problem… thoughts welcome!
26 Jul 2024 14:05 #256939 by lesgrandepotato
Replied by lesgrandepotato on topic Starter motor tech
After a careful! Consideration and knowing I need the car to start this weekend… I’ve grabbed a new one from the autofactors.
Autopsy on the old one to follow
26 Jul 2024 18:12 #256944 by lesgrandepotato
It’s clearly not my day. New starter swapped in and it sparks up first turn.
Second turn. Click of doom.
Third turn dash lights dim.
We’ve got a relay on the starter signal.
The starter is literally connected to each side of the battery.
26 Jul 2024 18:50 #256946 by Lambert
Replied by Lambert on topic Starter motor tech
That makes me think it's either immensely bad luck or something somewhere is seized and making it difficult for the starter?
26 Jul 2024 19:06 #256947 by lesgrandepotato
It sounds fine when it started, and it pushes about in gear. I guess the gti motor is higher compression… I’ll pull the plugs as a test tomorrow.
I’ve got a spare battery on charge to rule that out.
26 Jul 2024 20:49 #256952 by Roger Fairclough
Replied by Roger Fairclough on topic Starter motor tech
If the motor and battery are designed to suit the GTI engine then there should be no problems with at least turning the engine over. As you are obviously having problems I would suggest you investigate the suitability and condition of the wiring. Plastering battery posts with grease is useless if the surfaces of the posts and connections are covered with sulphates.
Roger
The following user(s) said Thank You: lesgrandepotato
Time to create page: 0.474 seconds
