Grand Vitara bearing support
  • Muddymoss
23 Jan 2016 14:55 #160931 by Muddymoss
Grand Vitara bearing support was created by Muddymoss
Hi, how many of you have fitted the nylon drive shaft support bearing behind the drivers side oil seal on the front diff?
  • S200KYS
23 Jan 2016 15:19 - 23 Jan 2016 15:20 #160934 by S200KYS
Replied by S200KYS on topic Grand Vitara bearing support
Hundreds...
LOL, I sell them all around the world... ;)
Dave, Bits4Vits B)
Edit : But you probably won't get much response on a Jimny biased forum... :whistle:
Last edit: 23 Jan 2016 15:20 by S200KYS.
23 Jan 2016 18:23 #160968 by Rhinoman
There should have been some sort of bearing in there from the start, the shaft surface can wear quite badly without it. Its so cheap its not worth running without one.
The following user(s) said Thank You: S200KYS
  • Muddymoss
23 Jan 2016 18:43 #160970 by Muddymoss
Replied by Muddymoss on topic Grand Vitara bearing support
Thanks, I've seen them on your site. Do you sell the 2" lift kit for a 53 plate Grand Vitara swb petrol? Also the 12.5mm propshaft spacer? Thanks
Paul
  • S200KYS
23 Jan 2016 18:55 #160975 by S200KYS
Rhinoman wrote: There should have been some sort of bearing in there from the start, the shaft surface can wear quite badly without it. Its so cheap its not worth running without one.
Thanks Rhinoman B)
  • S200KYS
23 Jan 2016 18:57 #160976 by S200KYS
Muddymoss wrote: Thanks, I've seen them on your site. Do you sell the 2" lift kit for a 53 plate Grand Vitara swb petrol? Also the 12.5mm propshaft spacer? Thanks
Paul
Ah, no, sorry... I'm not selling lift kits at the moment :( You'll be wanting JimnyBits for the lift kit...
Prop Spacers are in transit at the moment though... a batch are winging their way over from Rockwatt Engineering as we 'speak'...
Dave
Time to create page: 0.299 seconds
