Re:Andy's 2019 Blue SZ5
30 Apr 2019 19:51 #207012 by mlines
Replied by mlines on topic Andy's 2019 Blue SZ5
But the new ones are pretty much the same size?
  • Andy2640
  • Visitor
  • Visitor
30 Apr 2019 19:53 #207013 by Andy2640
Replied by Andy2640 on topic Andy's 2019 Blue SZ5
Kinda... 195/80/15 to 215/75/15
30 Apr 2019 19:59 #207014 by mlines
So close enough to be the same on the plate
The following user(s) said Thank You: Andy2640
  • Andy2640
  • Visitor
  • Visitor
30 Apr 2019 20:01 #207015 by Andy2640
Great, thank you.
30 Apr 2019 20:08 #207016 by Lambert
Replied by Lambert on topic Andy's 2019 Blue SZ5
On the vin plate it will give you the individual axle weight front and rear. On the side of the tyre it will have the maximum weight that the tyre can take at a maximum pressure. So using mathematics you know what they maximum weight that the axle will carry, divide that by the 2 tyres. You now know how much maximum weight each tyre is going to experience. So now with the information off the tyre you can work out how many psi the tyre needs to support 1 kg. Knowing that you can then multiply it by the half axle weight you worked out first. This will give you the correct psi for your tyres at maximum vehicle weight. It will be within 1 or 2 psi of the standard 26 psi all round. Simples.
  • Andy2640
  • Visitor
  • Visitor
01 May 2019 05:31 #207032 by Andy2640
Replied by Andy2640 on topic Re:Andy's 2019 Blue SZ5
Ive had some great advice here, and it is much appreciated, so feel free to scoff at my mathematical musings ;-)
Ok, but as we have stated before, the 215/75/15 has a 4.5% (approx) size difference. I'm assuming it also translates into a volume % too.
So wouldn't it stand that on top of 26 PSI we should add 4.5% ??
01 May 2019 06:15 #207038 by Lambert
Replied by Lambert on topic Re:Andy's 2019 Blue SZ5
Volume and pressure are two different things. Yes a bigger tyre holds more air than a smaller one but that just means you have to have more air to achieve the same pressure. The same amount of air in a smaller space will be under more pressure but by releasing some of the air you can regulate the pressure. If that makes sense.
01 May 2019 06:21 #207040 by Lambert
Lambert wrote: Volume and pressure are two different things. Yes a bigger tyre holds more air than a smaller one but that just means you have to have more air to achieve the same pressure. The same amount of air in a smaller space will be under more pressure but by releasing some of the air you can regulate the pressure. If that makes sense.
The volume of a tyre is consistent regardless of the volume of air you put into it. What changes is the pressure of the air as you introduce more volume of air into the fixed volume of the tyre.
01 May 2019 06:43 #207042 by Lambert
Except that that doesn't take into account the potential differences in tyre construction which affect the ability to carry weight at different pressures. Hence working it out from the specific information off the side of the tyre.
  • Andy2640
  • Visitor
  • Visitor
01 May 2019 07:19 - 01 May 2019 07:22 #207046 by Andy2640
Lambert wrote: Except that that doesn't take into account the potential differences in tyre construction which affect the ability to carry weight at different pressures. Hence working it out from the specific information off the side of the tyre.
I think I get this now.
Its like this > (I THINK) If we had two rubber cubes (both rated at 30psi) The first is 1m by 1m. And we also have the other rubber cube 2m by 2m. Whilst the 2 by 2 would require more air (volume), they would both need to be under pressure of 30PSI.??
That melted my brain.
Last edit: 01 May 2019 07:22 by Andy2640.
01 May 2019 07:31 #207047 by Lambert
Essentially yes.
01 May 2019 07:32 #207048 by Lambert
Think of it like this....
Because, science.
