Another Jimny Owner here
  • Mumbo Jimbo
09 Nov 2010 21:15 - 09 Nov 2010 21:16 #5840 by Mumbo Jimbo
Another Jimny Owner here was created by Mumbo Jimbo
Hi, I'm Trev - I drive a 2002 Automatic Jimny with Aircon
At the moment it's pretty standard compared to some I've seen on here
215/75/15 BF Goodrich MT's on standard wheels
ARB Front bumper
ASFIR skidplate for the front diff
Wobbly steering wheel between 40 and 45 mph - but I see I'm not the only one with this problem :unsure: So far I've solved this problem by either driving below 40 or over 45 mph :dry: Will need to check the Kingpins and front Bearings this weekend I think.
Need a lift soon as the front tyres seem to want to remove the front wheelarches when I get a bit carried away :silly: Want to fix the wheel wobble first though.
Hopefully some pics will appear below somewhere if I've done this right :blink:
Attachment 08-07-2010 781.jpg not found
Attachment 08-07-2010 764.jpg not found
Last edit: 09 Nov 2010 21:16 by Mumbo Jimbo.
  • darthloachie
09 Nov 2010 21:31 #5841 by darthloachie
Replied by darthloachie on topic Re: Another Jimny Owner here
Hi, welcome to the forum
Nice jimny, i like red ones B)
Where did you get your asfir skidplate from?
  • Mumbo Jimbo
09 Nov 2010 21:41 #5842 by Mumbo Jimbo
Replied by Mumbo Jimbo on topic Re: Another Jimny Owner here
Cheers :)
Would like mine to look more like yours by the time I'm finished with it! B)
Got the skidplate from offroad24.co.uk It reduces the ground clearance under the front diff a fair bit, but no lower than the brackets that the lower arms bolt to - not caused any problems so far.
  • Mumbo Jimbo
09 Nov 2010 22:04 - 09 Nov 2010 22:05 #5843 by Mumbo Jimbo
Some pics having fun in Picadilly Wood earlier this year
Attachment Picadilly Wood 07-02-10 1.jpg not found
Managed to get stuck in the same spot as the Disco on the way back through and needed winching out
Attachment DSC00266.jpg not found
Last edit: 09 Nov 2010 22:05 by Mumbo Jimbo.
10 Nov 2010 13:59 #5848 by kirkynut
You've got the beginnings of a nice little Jimny there. I look forward to seeing it with a lift on it, what height you thinking of lifting it? I like the look of the Off Road Armory 4.5" lift. You could fit some decent sized tyres then with a Rocklobster in time!
The Asfir skid plates seem quite good, although they can get bashed out of shape and need knocking back. That's the beauty of them though, they can get knocked back and they saved the component they were protecting. The diff guards might not be so dentable though given their shape.
I have a fuel tank guard from them and had a transfer box guard until I fitted my Rocklobster.
They're not cheap though - diff guards at over £200.00 each! No-one else has a bolt on solution though!
Keep the pictures coming as you modify it!
I like red Jimny's!!!;)
The following user(s) said Thank You: Mumbo Jimbo
  • Mumbo Jimbo
10 Nov 2010 19:14 #5859 by Mumbo Jimbo
Cheers Kirkynut - have been looking at the ORA 4.5" lift too - does look good for the money.
The biggest problems I've come across while offroading the Jimny have bee a lack of ground clearance so bigger tyres seem to be the way to go. I'm planning on fitting 31" tyres too if they'll fit. So I've just picked up a 31" BF Goodrich MT KM2 to see how much higher I need to go.
Rocklobster would be cool too - as would a locking diff or 2, the want list is growing by the day.
Diff guard was pricey but I'm sure I paid less than £200 - seems solid enough though.
Will keep updating the pics as I go! :)
Time to create page: 0.196 seconds
