Suzuki Jimny on air suspension
- g r e e n
- Visitor
11 Oct 2013 10:10 - 11 Oct 2013 10:11 #85795
by g r e e n
Suzuki Jimny on air suspension was created by g r e e n
Suspension lift is about 5" and can vary
Coil springs have been replaced to air bags.
4 gals air tank is supplier of air for suspension, front ARB air locker and sometimes to fill tyres.
Front winch is Superwinch Talon 9.5.
Tyres are Interco Super Swamper LTB 34x10.5.16.
Stock t-case was replaced to Samurai t-case with 4.9 KIT.
Front axle housing was rewelded. Radius arms over axle.
Stock front half-shafts were replaced to bigger shafts with Samurai cv-joints.
LockRight in rear diff and ARB in front.
Rear axle is full floater with disc brakes.
Last edit: 11 Oct 2013 10:11 by g r e e n. Reason: added one pic
- Dave cc
- Visitor
11 Oct 2013 11:36 #85801
by Dave cc
Replied by Dave cc on topic Suzuki Jimny on air suspension
Nice job mate well impressed with that where did you source the air bags from ?
- g r e e n
- Visitor
11 Oct 2013 11:47 #85802
by g r e e n
Replied by g r e e n on topic Suzuki Jimny on air suspension
Jimny is so small and light car so I don't have much choice. I found only two suitable sleeves. Firestone WO2-358-7012 and W26-358-9004. Other airbags are too large for our car.
I bought them on airbaggit.com.
- gaz3359
- Visitor
11 Oct 2013 11:55 #85803
by gaz3359
Replied by gaz3359 on topic Suzuki Jimny on air suspension
Very smart ! Like it.
- TomDK
- Visitor
11 Oct 2013 13:02 - 11 Oct 2013 13:03 #85810
by TomDK
Replied by TomDK on topic Suzuki Jimny on air suspension
Looks like a great job. Just not sure I see why.
Looks like you have lesser articulation than with normal shocks, these airbags don't look very tall. Probably why you have these Blocks on top and below them ?
If I should change suspension on the Jimny, I'd go for Fox Air Shocks.
Last edit: 11 Oct 2013 13:03 by TomDK.
- g r e e n
- Visitor
11 Oct 2013 14:36 #85821
by g r e e n
I can not brag about huge articulation and I don't worry about that. Total travel length of these air springs is about 15 cm. It's enough for me. I need comfortable suspension to drive on bumpy road. Also when I put a lot of things in my car it does not sag to bump stops because I inflate air bags more and go on same height as on empty car.
Air bags are empty. The car lays on bump stops
And this is ride height
- Goniu
- Visitor
23 Oct 2013 05:46 #87569
by Goniu
Replied by Goniu on topic Suzuki Jimny on air suspension
Nice! Interesting solution. Can you tell more about rear disc brakes? From which car solution to fit on Jimny axle. Because I see that you have a emergency brake is not hydraulic.
- g r e e n
- Visitor
24 Oct 2013 03:06 #87689
by g r e e n
I swapped rear axle to full floater. Did you see design of rear axle TLC80? My Jimny has same.
I made custom rear half-shafts, mounting for spindle and calliper. All other parts are original Suzuki except brake calliper.
This mod gives you rear disc brakes, removes weak rear half-shaft bearing which dies after first crossing river, and emergency brake which really works.
At first time I used callipers from Honda Accord but later I found Golf IV rear callipers. They are smaller and requiring less work to do.
- MRocha
- Visitor
24 Oct 2013 20:52 #87808
by MRocha
Replied by MRocha on topic Suzuki Jimny on air suspension
interested jimny...very cool!
- Genie4x4
- Visitor
04 Apr 2014 11:40 #111202
by Genie4x4
Replied by Genie4x4 on topic Re:Suzuki Jimny on air suspension
Is each number for each airbag? Are each side different?
Sent from my GT-I9505 using Tapatalk
- g r e e n
- Visitor
04 Apr 2014 11:59 #111203
by g r e e n
Replied by g r e e n on topic Re:Suzuki Jimny on air suspension
All four airbags are same. It's Firestone F9000.
04 Apr 2014 12:08 #111206
by Busta
Replied by Busta on topic Suzuki Jimny on air suspension
Why did you go for the 9000 rather than the 7000 airbags?
What is the ride quality like? Is it soft or firm?
Time to create page: 0.174 seconds
