My new trialler
This is what it looked like when I bought it
and this what it looks like now.
It had a snorkel, well a piece of rubber hose, running up the side of the windscreen with nothing on the top. After a bit of routing around I found a Durgo valve, or air admittnace valve for a 4inch soil pipe. After a bit of modding and a touch of paint its installed on the Jimny. Does the job and cost me nothing!
Sorry - don't know why the pic didn't insert itself
- Sponnie
- Visitor
- Blissett
- Visitor
Good luck
Mark
And that a good idea for a snorkel top, now when l go to the loo at work and flush the toilet i will be reminded of your snorkel. :sick:
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Good to know it'll be remembered when you flush the toilet!
- nicho
- Visitor
- Dan_w
- Visitor
Nicho - it belonged to my nephew and he bought it from Neil Whitford AWDC guy behind the King of the Valleys. So it's been around for quite some time. I helped my nephew make some of the changes to the car so know it quite well.
Be interesting to see how it goes. It's certainly very low geared now with the 5:1 transfer box and we had already put vvt diffs in along with a 410 transfer box.
Good fun anyway!
- phippj1
- Visitor
Does this mean the cage flex increases. These cages have a habit of hitting the car, my Jimny is an almost identical KAP build and you should see the cost the original owner was charged for the flexible pipe snorkle!
Yes I did remove it as it seemed to be directly in my line of vision and I thought that as a trialler, or any other use really, it was not a desirable situation! So I got the angle grinder out and it was soon gone! I'm not sure the cage is any more flexible but I can imagine it would hit the body. I think really it needs a diagonal to brace it better, and possibly an external diagonal above the cab too. The cage is not that well made, it overhangs the rock sliders where the pipe hasn't been shaped to fit, and also where it fits the rear bumper doesn't look that strong.
I did wonder about putting an internal cage in it fixed directly to the chassis with a continuos hoop, diagonal and 2 rear bars. It would then conform to MSA spec and be eligible for a different class of trial. Possibly then bracing it to the external cage but I'm not sure if it would then conform to MSA! Need to check that out with a scrutineer.
I thought my snorkel top was rather good and very simple, but also very effective. I removed the external rubber fitting from the Durgo that normally fits inside the soil pipe, cut it down so that it fitted inside the Durgo pipe, and then inserted a piece of gutter down pipe into the rubber. The flexible 'snorkel' just happened to be a good fit in the gutter down pipe. I took the guts of the Durgo out before I started so that its open inside.
- supergaz
- Visitor
Obarno wrote: Hi Martin
I did wonder about putting an internal cage in it fixed directly tThe cage is not that well made, it overhangs the rock sliders where the pipe hasn't been shaped to fit, and also where it fits the rear bumper doesn't look that strong.o the chassis with a continuos hoop, diagonal and 2 rear bars. It would then conform to MSA spec and be eligible for a different class of trial. Possibly then bracing it to the external cage but I'm not sure if it would then conform to MSA! Need to check that out with a scrutineer.
I have a KAP cage and KAP rear bumper, and the bumper is no place to mount the rear cage hoop, I reinforced mine with a length of box section inside before fitting my e'bay sourced cage/rear bumper, Also my rear bumper was twisted when I got it and required some work to get straight. I also removed my brace in front of the windscreen as it caused an MOT fail and I knew it is illegal for road use The cage never has contacted the body maybe due to the box section welded to the chassis? and removing the brace seems to make no difference, even though i'm planning on trying to replace it with it lower than it was originally fitted.
