Miguels Jimny build
26 Feb 2010 20:39 - 26 Feb 2010 20:40 #2493 by mlines
Miguels Jimny build was created by mlines
Miguel has sent in a great write up on his Jimny build so far. Take a look HERE for details.
Last edit: 26 Feb 2010 20:40 by mlines.
  • ooky_123
26 Feb 2010 22:12 #2494 by ooky_123
Replied by ooky_123 on topic Re:Miguels Jimny build
That looks good
01 Mar 2010 06:08 - 02 Mar 2010 05:48 #2507 by MigCooper
Replied by MigCooper on topic Re:Miguels Jimny build
Hi
Wondering what others did with the rear brakes spring in " Image 7 "? :unsure:
Did you remove it? :unsure:
Regards
Thanks for the help.
Snorkel and plenty of rust to be treated :)
Last edit: 02 Mar 2010 05:48 by MigCooper.
05 Mar 2010 08:56 #2570 by MigCooper
MigCooper wrote:
Hi
Regards
??? No ideas? sure someone has an idea? :(
05 Mar 2010 09:05 #2571 by mlines
Replied by mlines on topic Re:Miguels Jimny build
I have a KAP 3" lift and I adjusted the spring so that it continues to work. It adjusts the rear brakes depending on the load in the rear of the car. There is a bolt on in that you can loosen and adjust
05 Mar 2010 10:05 #2575 by MigCooper
Thanks Martin
I will have a look at that and post the results later ;)
Time to create page: 0.196 seconds
