Don's Jimny
- doncarlyon
- Visitor
11 Apr 2011 06:06 #14808
by doncarlyon
Replied by doncarlyon on topic Re: Don's Jimny
Got some Aisin manual hubs on the way, just need to order the spacer rings/bolts and we'll see if its any better power wise and mpg aswell.
11 Apr 2011 06:52 - 11 Apr 2011 06:52 #14811
by ooky_123
Former owner of Little "Ooky", who has now started a new life in Shetland
Replied by ooky_123 on topic Re: Don's Jimny
The Vac system is controlled by 2 solenoids under the main fuses by the battery. there are small airfilters / vents on these and they can become blocked with mud / dirt etc.
or, of coruse you could damage one fo the pipes under the car which will result in no vacuum, so when you select 4x4, the front hubs will not "ping" and lock, and after 30 seconds, your 4x4 light on the dash will flash, indicating a fault.
Last edit: 11 Apr 2011 06:52 by ooky_123.
- doncarlyon
- Visitor
14 Apr 2011 11:18 #15013
by doncarlyon
Aisin hubs have arrived, just need the bigjimny shop to open so i can order the adaptors now.
Am i right in thinking i can change the hubs with the wheels in place, no need to jack it up, etc?
- Keefe
- Visitor
14 Apr 2011 11:27 #15014
by Keefe
Replied by Keefe on topic Re: Don's Jimny
I do believe that's correct. In fact, I'm sure it is.
When is Martin back as I need a pair of spacers as well?
- doncarlyon
- Visitor
14 Apr 2011 12:21 #15015
by doncarlyon
think he said the shop is open this weekend
- Keefe
- Visitor
14 Apr 2011 15:04 - 14 Apr 2011 15:07 #15019
by Keefe
Anything in this link of interest to you?
forum.difflock.com/search.php?mode=results
K
EDIT:
That link doesn't work. Just type in aisin and hub in the search box. Loads of stuff comes up.
K
EDIT:
Last edit: 14 Apr 2011 15:07 by Keefe.
