Name that sound...
  • Rich-lj
16 Jun 2009 14:11 #801 by Rich-lj
Name that sound... was created by Rich-lj
On my way to work this morning I could hear a faint noise coming from what sounded like the front passenger side wheel area. It sounded like a bearing that has gone dry, but only made a noise just as I accellerated or just as I lifted off the accellerator for a split second. On my way home tonight it was still doing it, I went through the toll booths on the bridge and as I was setting off down the dual carriageway and i started getting a louder noise from the rear. I sounded like I had muds on, which I do, so I thought maybe I had a flat or soft tyre but when I checked they were all fine.
Are both these noises the same problem and it just sounded like it was coming from the front, and what is it likely to be? :(
17 Jun 2009 08:42 #802 by mlines
Replied by mlines on topic Re:Name that sound...
Rich
I have found it really hard to diagnose these. Noises that appear to come from the front with the windows closed can appear to come from the back when the windows are open.
It could be so many things from wheel bearings, UJs to clutch release bearings, transfer box chain or differentials.
I would suspect a rear wheel bearing or transfer chain noise first.
  • Rich-lj
17 Jun 2009 15:06 #804 by Rich-lj
Replied by Rich-lj on topic Re:Name that sound...
When I got home I had a look and put my hand on the diff case, it was very warm. I'm guessing it isn't supposed to get warm/hot?
If its the t-chain, is there any way of inspecting it without taking the whole box out and stripping it?
  • Rich-lj
17 Jun 2009 18:42 #806 by Rich-lj
ok, I got the thing up on axle stands earlier and put it in gear and let it drive its self. With the jack handle stuck in my ear I made out that the sound was coming from just behind the passenger side rear brake, I assume that is where the bearing is sat? Hopefuly thats what it is.
Does anyone know the part numbers for a rear bearing and any seals required to do the job and also Is there a guide to doing it anywhere? I'm sure its a straight forward job, but I'd like to make sure I'm set for doing it before I pull it all apart.
18 Jun 2009 05:21 - 18 Jun 2009 05:23 #807 by mlines
Do you really need to ask ;)
The guide to doing it is HERE
and I sell the bearings and seals in the Bigjimny shop
The bearing and oil seal kit is £22.00
The bearing, retainer ring (NON-ABS Cars only) and oil seal kit is £37.26
Both are about £2.14 to post first class
The reason for offering two kits is because the retainer ring is actually slightly cheaper from the Suzuki dealer (about £1 cheaper) so you may want to save a £1 and get it from your dealer.
All prices include VAT.
BUT - if you look at the shop this morning they are not listed as I am awaiting stock, my supplier emailed me yesterday lunch to say they had been dispatched on next day delivery so they should be in later today. Once they are in then they will appear.
Last edit: 18 Jun 2009 05:23 by mlines.
18 Jun 2009 12:24 #810 by mlines
Now back in stock!
