Head Gasket
01 Aug 2025 16:19 #261437 by Sy
Head Gasket was created by Sy
Hello. Ive got a 2008 Jimny on 148000. Suspect my head gasket has gone and wondering if anyone can confirm this please. Started having coolant leaks.
First on the throttle body metal pipe and then a week later the same on the thermostat housing. Today the radiator drain plug appears to have blown out and leaked all the coolant.
The coolant reservoir level increases and doesn't go back down when cold and the old coolant was thick and an orange colour. There's no smoke from the exhaust and the oil looks normal.
Is this likely to pressure created by leaking exhaust gases to the coolant?
Thanks.
Sy
01 Aug 2025 16:29 #261438 by Lambert
Replied by Lambert on topic Head Gasket
Welcome to the forum. Short answer, yes.
With an m13 once it does get hot hot it will have eaten its head gasket, it's just one of those engines when it's fine it's fine but as soon as it's not fine you're done.
01 Aug 2025 17:21 #261439 by Sy
Replied by Sy on topic Head Gasket
Thanks for the welcome and thanks for the quick response.
Is it just a case of a new gasket or is skimming the head essential?
01 Aug 2025 18:38 #261442 by fordem
Replied by fordem on topic Head Gasket
Anytime you have an aluminium alloy engine apart, the head AND block should be checked, I'm not saying skimmed, but at the very least, checked to ensure that a skim is not required.
01 Aug 2025 18:50 #261443 by Lambert
When mine went it needed less than 2 thousandths off. My mates sons needs 8 on the head and 2 on the block aka a new motor.
02 Aug 2025 06:56 #261451 by Sy
Thanks for information. Ill be attempting this myself as funds won't cover mrehanic labour costs.
Time to create page: 0.234 seconds
